Ana içeriğe geç
Microsoft Surface Headphones Motherboard Replacement
Neye ihtiyacın var
  1. Microsoft Surface Headphones Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Microsoft Surface Headphones Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Firmly grasp the ear cushions and rotate them counterclockwise, about 45 degrees, until you hear a "click."
    • To replace the motherboard, you only need to remove the right cushion, labeled with an "R" on the headband.
  2. Microsoft Surface Headphones Motherboard Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 2.6 mm screws securing the right speaker housing to the chassis.
  3. Microsoft Surface Headphones Motherboard Replacement: adım 3, 1 resimden 1.
    • Lift the speaker housing away from the chassis, taking care not to damage the motherboard connections.
    • Desolder the two speaker motherboard connections.
    • Desoldering and soldering are delicate procedures, and there is a potential for device damage.
  4. Microsoft Surface Headphones Motherboard Replacement: adım 4, 1 resimden 1.
    • Desolder the red and black speaker connections.
  5. Microsoft Surface Headphones Motherboard Replacement: adım 5, 1 resimden 1.
    • Desolder the 23 connections from the motherboard.
    • Before soldering the connections to your new motherboard, be sure to pay close attention to which wire goes where; they're very easy to mix up.
  6. Microsoft Surface Headphones Motherboard Replacement: adım 6, 1 resimden 1.
    • Use a Torx screwdriver to remove the four screws.
    • Lift the motherboard up and out of the chassis.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 970
