Ana içeriğe geç
Microsoft Surface Headphones Speaker Replacement
Neye ihtiyacın var
  1. Microsoft Surface Headphones Speaker Replacement, Ear Cushion: adım 1, 1 resimden 1.
    • Firmly grasp the ear cushions, and rotate them counterclockwise about 45 degrees, or until you hear a "click."
    • Be careful not to use excessive force during rotation.
  2. Microsoft Surface Headphones Speaker Replacement: adım 2, 1 resimden 1.
    • Lift the ear cushions off the speaker housings.
  3. Microsoft Surface Headphones Speaker Replacement, Speaker: adım 3, 2 resimden 1. Microsoft Surface Headphones Speaker Replacement, Speaker: adım 3, 2 resimden 2.
    • Remove the six 2.6mm screws with a Phillips #00 screwdriver, and gently lift the speaker housings away.
    • If only one of the speakers is malfunctioning, only remove the screws on the affected side, and leave the functional speaker intact.
  4. Microsoft Surface Headphones Speaker Replacement: adım 4, 2 resimden 1. Microsoft Surface Headphones Speaker Replacement: adım 4, 2 resimden 2.
    • Gently pry the speaker housing away from the chassis with a spudger.
  5. Microsoft Surface Headphones Speaker Replacement: adım 5, 1 resimden 1.
    • Desolder the speaker's motherboard connections.
    • Desoldering and soldering are delicate procedures, and there is a potential for device damage.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
5 Yorum
How can I get my turtle Beach to pair
Miguel Garcia - Yanıt
How do I remove the speaker from the plastic housing? Is it glued in place? I desoldered the speaker unit and now I am trying to take out speaker from its housing.
Stephen Hyland - Yanıt
I would also like to know this! replacing the speaker requires the plastic housing to be opened. I tried heating the housing with a hair dryer but no result....
fixer8888 -
I cut it in half down the side. Very long a tedious process. also makes it hard to get a tight seal for reassembly but with a little more patience than I had and a clamp to glue the pieces together could probably get a nice finish. I have a gap which causes a little weirdness for the ANC especially with wind.
joshray -
Where do you get replacement speaker
marilyn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 16
Son 30 gün: 58
Her zaman: 1,780
