Giriş
In this guide, we will be replacing the kickstand on a Microsoft Surface Pro 2. The procedure is quite simple and does not require taking the screen off of the device, so you won’t need to deal with heat or prying at all. Follow this guide if your kickstand is damaged by impact or stress and needs to be replaced.
Neye ihtiyacın var
Lift the kickstand up from the back of the device to reveal the hinges.
Remove the single Torx T5 screw from each hinge (two total).
Sonuç
