Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Microsoft Surface Pro 4 Heat Sink Replacement
Neye ihtiyacın var
  1. Microsoft Surface Pro 4 Heat Sink  Replacement, Heat Sink: adım 1, 3 resimden 1. Microsoft Surface Pro 4 Heat Sink  Replacement, Heat Sink: adım 1, 3 resimden 2. Microsoft Surface Pro 4 Heat Sink  Replacement, Heat Sink: adım 1, 3 resimden 3.
    • Both sections of the heat sink are connected to the motherboard via a panel which is covered by a metal casing.
    • Remove the casing by prying around the edges and then lifting the entire piece once it is loose.
  2. Microsoft Surface Pro 4 Heat Sink  Replacement: adım 2, 3 resimden 1. Microsoft Surface Pro 4 Heat Sink  Replacement: adım 2, 3 resimden 2. Microsoft Surface Pro 4 Heat Sink  Replacement: adım 2, 3 resimden 3.
    • Remove the four 1.5mm Torx T4 screws holding the main body of the heat sink to the motherboard
  3. Microsoft Surface Pro 4 Heat Sink  Replacement: adım 3, 2 resimden 1. Microsoft Surface Pro 4 Heat Sink  Replacement: adım 3, 2 resimden 2.
    • Remove the 1.5mm Torx T3 screw holding the copper plate near the bottom of the device.
  4. Microsoft Surface Pro 4 Heat Sink  Replacement: adım 4, 2 resimden 1. Microsoft Surface Pro 4 Heat Sink  Replacement: adım 4, 2 resimden 2.
    • Remove the 1.5mm Torx T4 screw holding the heat sink tubing to the frame of the device.
    • Remove the 3.0mm Torx T4 screw.
  5. Microsoft Surface Pro 4 Heat Sink  Replacement: adım 5, 3 resimden 1. Microsoft Surface Pro 4 Heat Sink  Replacement: adım 5, 3 resimden 2. Microsoft Surface Pro 4 Heat Sink  Replacement: adım 5, 3 resimden 3.
    • You can now remove entire heat sink by lifting it out with your hands.
    • Be sure to replace the thermal paste when installing the heat sink.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Andrew Prater
5.731 İtibar
4 adet Kılavuz yazıldı
Ekip
Metro State, Team 1-3, Carpenter Spring 2016 Metro State, Team 1-3, Carpenter Spring 2016 üyesi
MSU-CARPENTER-S16S1G3
2 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 49
Son 30 gün: 218
Her zaman: 19,054
