Ana içeriğe geç
Microsoft Surface Pro 4 Kickstand Replacement
Neye ihtiyacın var
  1. Microsoft Surface Pro 4 Kickstand Replacement, Open the kickstand: adım 1, 3 resimden 1. Microsoft Surface Pro 4 Kickstand Replacement, Open the kickstand: adım 1, 3 resimden 2. Microsoft Surface Pro 4 Kickstand Replacement, Open the kickstand: adım 1, 3 resimden 3.
    • Place your device screen-down on a clean work surface.
    • Place your device on top of a clean cloth, such as a microfiber towel, if you feel the need to protect against scratching.
    • Open the kickstand as wide as it is designed to go (about 135 degrees).
  2. Microsoft Surface Pro 4 Kickstand Replacement, Unscrew the kickstand: adım 2, 2 resimden 1. Microsoft Surface Pro 4 Kickstand Replacement, Unscrew the kickstand: adım 2, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the two 3.3 mm screws securing each hinge to the kickstand.
    • Support the kickstand from behind to prevent damage to the hinges while removing the screws.
    • Do not remove the kickstand yet.
    • The kickstand remains held in place by two flexible appendages between the hinges.
  3. Microsoft Surface Pro 4 Kickstand Replacement, Close the kickstand: adım 3, 3 resimden 1. Microsoft Surface Pro 4 Kickstand Replacement, Close the kickstand: adım 3, 3 resimden 2. Microsoft Surface Pro 4 Kickstand Replacement, Close the kickstand: adım 3, 3 resimden 3.
    • Press the kickstand from directly behind the hinges and close it fully.
    • Do not exert force on the kickstand anywhere except for behind the hinges.
    • This step does not apply during reassembly.
  4. Microsoft Surface Pro 4 Kickstand Replacement, Remove the kickstand: adım 4, 3 resimden 1. Microsoft Surface Pro 4 Kickstand Replacement, Remove the kickstand: adım 4, 3 resimden 2. Microsoft Surface Pro 4 Kickstand Replacement, Remove the kickstand: adım 4, 3 resimden 3.
    • Pull the kickstand straight out from the bottom of the device.
    • Begin reassembly now before proceeding to steps 5 and 6:
    • Install your new kickstand by inserting its two appendages into the back of the device.
    • Press your new kickstand towards the top of the device until it is fully inserted.
    • Open the kickstand 180 degrees to expose the hinges.
  5. Microsoft Surface Pro 4 Kickstand Replacement, Reassembly tips: adım 5, 3 resimden 1. Microsoft Surface Pro 4 Kickstand Replacement, Reassembly tips: adım 5, 3 resimden 2. Microsoft Surface Pro 4 Kickstand Replacement, Reassembly tips: adım 5, 3 resimden 3.
    • To open the hinge, insert your T5 Torx screwdriver into one of the screw holes and gently pry towards the top of your device until the hinge is exposed.
    • Make sure the complete step 4 and begin installing the kickstand first.
  6. Microsoft Surface Pro 4 Kickstand Replacement: adım 6, 2 resimden 1. Microsoft Surface Pro 4 Kickstand Replacement: adım 6, 2 resimden 2.
    • Use your fingers or the flat end of a spudger to pry the hinge up into its fully open position.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
73.215 İtibar
288 adet Kılavuz yazıldı
3 Yorum
Is there a way to fix or replace the hinge? The kickstand on my Surface Pro is fine but the left hinge broke so now it won’t hold it up
Joel Hanson - Yanıt
Joel - did you find a solution? My left hinge broke a week ago and I’m looking for a solution. Thanks!
Cora Willett -
I’m sorry for the delayed reply. I didn’t check on the hinges when I was working on the guide and unfortunately I don’t have the device still. In my online research, I found that the hinges are replaceable but I wasn’t able to find replacement parts.
Sarah Westberg -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 32
Son 30 gün: 111
Her zaman: 10,228
