Ana içeriğe geç
Microsoft Surface Pro 5 Front and Rear Camera Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
    1. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Disconnect the display board: adım 1, 3 resimden 1. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Disconnect the display board: adım 1, 3 resimden 2. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Disconnect the display board: adım 1, 3 resimden 3.
      • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 2, 3 resimden 1. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 2, 3 resimden 2. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Use tweezers to slide the display cables straight out of their sockets on the display board.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the display board: adım 3, 3 resimden 1. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the display board: adım 3, 3 resimden 2. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the display board: adım 3, 3 resimden 3.
      • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
      FixBot'a Sor
      Yorum Ekle
    4. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 4, 1 resimden 1.
      Tesa 61395 Tape
      $8.95
      • Remove the display board.
      • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off the old adhesive before applying new adhesive.
      • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
      FixBot'a Sor
      Yorum Ekle
    5. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 5, 1 resimden 1.
      • Only the screen remains.
      FixBot'a Sor
      Yorum Ekle
    1. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the heat sink shield: adım 6, 2 resimden 1. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the heat sink shield: adım 6, 2 resimden 2.
      • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
      • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
      • Try not to deform the shield too much—you will need to reinstall it during reassembly.
      • Take care not to puncture the battery with the tweezers while working on this shield.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 7, 3 resimden 1. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 7, 3 resimden 2. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 7, 3 resimden 3.
      • Repeat the last step for each corner of the EMI shield covering the heat sink.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 8, 1 resimden 1.
      • Remove the heat sink shield.
      FixBot'a Sor
      Yorum Ekle
    4. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the heat sink: adım 9, 2 resimden 1. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the heat sink: adım 9, 2 resimden 2.
      • Remove the nine Torx screws securing the heat sink:
      • Five 2.6 mm-long T3 screws
      • Four 3.3 mm-long T5 screws
      • During reassembly, tighten the heat sink screws in the following criss-cross pattern, one turn at a time, until they're tight:
      • Screw 1
      • Screw 2
      • Screw 3
      • Screw 4
      FixBot'a Sor
      Yorum Ekle
    5. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 10, 3 resimden 1. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 10, 3 resimden 2. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 10, 3 resimden 3.
      FixBot'a Sor
      Yorum Ekle
    1. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Camera Tie Bar: adım 11, 1 resimden 1.
      • Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 12, 1 resimden 1.
      • Remove the remaining three Torx T5 x 4.5mm screws holding down the camera tie bar.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 13, 1 resimden 1.
      • Disconnect the small ribbon cable connecting the camera tie bar to the motherboard by pulling up with tweezers.
      FixBot'a Sor
      Yorum Ekle
    4. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 14, 1 resimden 1.
      • Lift the camera tie bar off of the device.
      FixBot'a Sor
      Yorum Ekle
    1. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Front and Rear Camera: adım 15, 1 resimden 1.
      • Pry off the metal cover covering the front and rear camera ribbon cable motherboard connections using a nylon spudger.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 16, 1 resimden 1.
      • Lift the front camera ribbon cable off the motherboard using the nylon spudger.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 17, 1 resimden 1.
      • Remove the front camera.
      FixBot'a Sor
      Yorum Ekle
    4. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 18, 1 resimden 1.
      • Remove the two Torx T3 x 2.5mm screws holding down the rear camera.
      FixBot'a Sor
      Yorum Ekle
    5. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 19, 1 resimden 1.
      • Lift the rear camera ribbon cable off the motherboard using the nylon spudger.
      FixBot'a Sor
      Yorum Ekle
    6. Microsoft Surface Pro 5 Front and Rear Camera Replacement: adım 20, 1 resimden 1.
      • Remove the rear camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Paul Manzer
762 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G3, Livingston Fall 2017 Cal Poly, Team S15-G3, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G3
3 Üyeler
74 adet Kılavuz yazıldı
1Rehber Yorum
In step 19, there is a loose, clear plastic piece next to the front camera. In my disassembly, that piece managed to get lost. Can anyone tell me what the name of that part is, and where I can get one?
Charley Ballmer - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 44
Her zaman: 2,049
