Ana içeriğe geç
Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Disconnect the display board: adım 1, 3 resimden 1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Disconnect the display board: adım 1, 3 resimden 2. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Disconnect the display board: adım 1, 3 resimden 3.
    • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
  2. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 2, 3 resimden 1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 2, 3 resimden 2. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to slide the display cables straight out of their sockets on the display board.
  3. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the display board: adım 3, 3 resimden 1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the display board: adım 3, 3 resimden 2. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the display board: adım 3, 3 resimden 3.
    • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
  4. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 4, 1 resimden 1.
    Tesa 61395 Tape
    $5.99
    • Remove the display board.
    • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off the old adhesive before applying new adhesive.
    • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
  5. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 5, 1 resimden 1.
    • Only the screen remains.
  6. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the heat sink shield: adım 6, 2 resimden 1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the heat sink shield: adım 6, 2 resimden 2.
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
    • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • Take care not to puncture the battery with the tweezers while working on this shield.
  7. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 7, 3 resimden 1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 7, 3 resimden 2. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 7, 3 resimden 3.
    • Repeat the last step for each corner of the EMI shield covering the heat sink.
  8. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 8, 1 resimden 1.
    • Remove the heat sink shield.
  9. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the heat sink: adım 9, 2 resimden 1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the heat sink: adım 9, 2 resimden 2.
    • Remove the nine Torx screws securing the heat sink:
    • Five 2.6 mm-long T3 screws
    • Four 3.3 mm-long T5 screws
    • During reassembly, tighten the heat sink screws in the following criss-cross pattern, one turn at a time, until they're tight:
    • Screw 1
    • Screw 2
    • Screw 3
    • Screw 4
  10. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 10, 3 resimden 1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 10, 3 resimden 2. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 10, 3 resimden 3.
  11. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Camera Tie Bar: adım 11, 1 resimden 1.
    • Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
  12. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 12, 1 resimden 1.
    • Remove the remaining three Torx T5 x 4.5mm screws holding down the camera tie bar.
  13. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 13, 1 resimden 1.
    • Disconnect the small ribbon cable connecting the camera tie bar to the motherboard by pulling up with tweezers.
  14. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 14, 1 resimden 1.
    • Lift the camera tie bar off of the device.
  15. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Power Button, Volume Buttons, and Left Speaker Assembly: adım 15, 1 resimden 1.
    • Use a Torx T5 to remove the two 4.5mm silver screws on the power button/volume control/speaker assembly.
  16. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 16, 2 resimden 1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 16, 2 resimden 2.
    • Disconnect the small ribbon attaching the assembly to the motherboard by lifting up with tweezers.
    • Disconnect the black and red cable connector by lifting up with tweezers.
  17. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: adım 17, 1 resimden 1.
    • Pull the assembly to the left with hands and lift up to remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kaden Foster
897 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G3, Livingston Fall 2017 Cal Poly, Team S15-G3, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G3
3 Üyeler
17 adet Kılavuz yazıldı
1Rehber Yorum
Hi,
Where can I purchase the power button assembly in the UK?
junaidpatel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 2,966
