Ana içeriğe geç
Microsoft Surface Pro 7 Screen Adhesive Replacement
Neye ihtiyacın var
    1. Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: adım 1, 3 resimden 1. Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: adım 1, 3 resimden 2. Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: adım 1, 3 resimden 3.
      • Scrape away all traces of adhesive and debris from the Surface's case and screen.
      • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
      • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
      • Lay the adhesive strips out to get an idea of where they go.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: adım 2, 2 resimden 1. Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: adım 2, 2 resimden 2.
      • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
      • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
      • Once aligned, use your fingers to press the adhesive strip down against the case.
      • Repeat this procedure for the remaining three adhesive strips.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Pro 7 Screen Adhesive Replacement, Install the display: adım 3, 1 resimden 1.
      • Continue reassembly until the cables are reconnected and you're ready to install the screen.
      • If possible, test your screen's functionality before sticking it in place.
      • Remove the clear backing from the adhesive strips.
      • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
      • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
99.897 İtibar
289 adet Kılavuz yazıldı
3Kılavuz Yorumları
Pictures of the original adhesive configuration would be helpful.
HuntTheHunters - Yanıt Paylaş
where can i buy the adshevies for surface pro 8 please
Joyce Woodhead - Yanıt Paylaş
Bonjour
Je voudrais savoir si ces adhésifs sont valable pour la surface 7+
Merci
Christophe - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 32
Son 30 gün: 116
Her zaman: 8,063
