Ana içeriğe geç
Microsoft Surface Pro 7 Screen Adhesive Replacement
Neye ihtiyacın var
  1. Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: adım 1, 3 resimden 1. Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: adım 1, 3 resimden 2. Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: adım 1, 3 resimden 3.
    • Scrape away all traces of adhesive and debris from the Surface's case and screen.
    • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
    • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
  2. Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: adım 2, 2 resimden 1. Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: adım 2, 2 resimden 2.
    • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
    • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
    • Once aligned, use your fingers to press the adhesive strip down against the case.
    • Repeat this procedure for the remaining three adhesive strips.
  3. Microsoft Surface Pro 7 Screen Adhesive Replacement, Install the display: adım 3, 1 resimden 1.
    • Continue reassembly until the cables are reconnected and you're ready to install the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Remove the clear backing from the adhesive strips.
    • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
92.272 İtibar
290 adet Kılavuz yazıldı
3Kılavuz Yorumları
Pictures of the original adhesive configuration would be helpful.
HuntTheHunters - Yanıt
where can i buy the adshevies for surface pro 8 please
Joyce Woodhead - Yanıt
Bonjour
Je voudrais savoir si ces adhésifs sont valable pour la surface 7+
Merci
Christophe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 33
Son 30 gün: 125
Her zaman: 7,045
