Ana içeriğe geç
Mid F900 Motherboard Replacement
Neye ihtiyacın var
  1. Mid F900 Motherboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Motherboard Replacement: adım 2, 2 resimden 1. Mid F900 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Motherboard Replacement, Motherboard: adım 3, 2 resimden 1. Mid F900 Motherboard Replacement, Motherboard: adım 3, 2 resimden 2.
    • Using a +00 Phillips head screwdriver, remove the screws securing the motherboard to the device housing.
    • Screws are 4mm x 1mm in size.
  4. Mid F900 Motherboard Replacement: adım 4, 2 resimden 1. Mid F900 Motherboard Replacement: adım 4, 2 resimden 2.
    • Desolder the two black and red wires connected to the motherboard.
    • Unclip and remove the ribbon cables attached to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
  5. Mid F900 Motherboard Replacement: adım 5, 2 resimden 1. Mid F900 Motherboard Replacement: adım 5, 2 resimden 2.
    • Carefully lift and remove the motherboard from the device housing.
Sonuç
Matthew Oliva
364 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-6, Remmell Fall 2016 USF Tampa, Team 6-6, Remmell Fall 2016 üyesi
USFT-REMMELL-F16S6G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 308
