Ana içeriğe geç
Mid F900 Speaker Replacement
Neye ihtiyacın var
  1. Mid F900 Speaker Replacement, Back Cover: adım 1, 1 resimden 1.
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Speaker Replacement: adım 2, 2 resimden 1. Mid F900 Speaker Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Follow the black and red wires coming from the white back plate to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
    • Carefully use the soldering iron to desolder the wires from the motherboard.
    • Do not keep the soldering gun on the motherboard for too long or damage may occur to the device.
  4. Mid F900 Speaker Replacement: adım 4, 1 resimden 1.
    • Use the nylon spudger to gently pry the speaker from the case. Then put the new speaker in.
    • You will need to resolder the wires from the new speaker to the motherboard.
Sonuç
Jacques Pierre
336 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-6, Remmell Fall 2016 USF Tampa, Team 6-6, Remmell Fall 2016 üyesi
USFT-REMMELL-F16S6G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 210
