Ana içeriğe geç
Midiman Oxygen 8 Data Entry Slide Bar Replacement
Scott Miller
Scott Miller ve 2 diğer katkıda bulunanlar
En son January 9, 2017 tarihinde güncellendi
Tahmin yok
Zor
Neye ihtiyacın var
  1. Midiman Oxygen 8 Data Entry Slide Bar Replacement, Midiman Oxygen 8 Backplate Disassembly: adım 1, 2 resimden 1. Midiman Oxygen 8 Data Entry Slide Bar Replacement, Midiman Oxygen 8 Backplate Disassembly: adım 1, 2 resimden 2.
    • Remove the 8 mm M3 Phillips head self tapping machine screws.
    • Several of the screws are in narrow, deep sockets; make sure to use an appropriate screw driver to remove them so as not to damage the cover during removal.
    • Remove all 13 of the back plate screws.
  2. Midiman Oxygen 8 Data Entry Slide Bar Replacement: adım 2, 2 resimden 1. Midiman Oxygen 8 Data Entry Slide Bar Replacement: adım 2, 2 resimden 2.
    • Remove the two highlighted 10 mm M3 galvanized machine screws using the J1 head fro the iFixit Tool Kit or a comparable tool.
  3. Midiman Oxygen 8 Data Entry Slide Bar Replacement: adım 3, 3 resimden 1. Midiman Oxygen 8 Data Entry Slide Bar Replacement: adım 3, 3 resimden 2. Midiman Oxygen 8 Data Entry Slide Bar Replacement: adım 3, 3 resimden 3.
    • Removal of Ribbon Cables
    • Prior to removal, note, mark, or take photo’s of the position of all connectors. Specifically note the side that the red wire is on, as ribbon cables are polarized cables that must be re-installed correctly. Installing the cables backwards may cause damage to the device or significantly hinder the troubleshooting process.
    • To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
  4. Midiman Oxygen 8 Data Entry Slide Bar Replacement: adım 4, 2 resimden 1. Midiman Oxygen 8 Data Entry Slide Bar Replacement: adım 4, 2 resimden 2.
    • Remove the key assembly from the key board.
    • What remains is the back plate and the top plate assemblies.
  5. Midiman Oxygen 8 Data Entry Slide Bar Replacement, Data Entry Slide Bar: adım 5, 1 resimden 1.
    • The Data Slide bar is attached to the same circuit as the LCD screen on the reverse of the front faceplate.
    • Remove the four M1.5 x 3 screws
  6. Midiman Oxygen 8 Data Entry Slide Bar Replacement: adım 6, 1 resimden 1.
    • These are the 12 contacts that must be de-soldered in order to remove the data entry slide bar, 4 are electrical and 8 secure the housing.
  7. Midiman Oxygen 8 Data Entry Slide Bar Replacement: adım 7, 1 resimden 1.
    • After de-soldering the part, you will be able to remove it and replace it.
Sonuç
Scott Miller
437 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Sullivan Fall 2016 USF Tampa, Team 1-6, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S1G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 541
