Ana içeriğe geç
Midland X-tra Talk Radio LXT118 Front buttons Replacement
Neye ihtiyacın var
  1. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Batteries: adım 1, 2 resimden 1. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Batteries: adım 1, 2 resimden 2.
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Front buttons Replacement: adım 2, 1 resimden 1.
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Case: adım 3, 1 resimden 1.
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Front buttons Replacement: adım 4, 1 resimden 1.
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Front buttons: adım 5, 1 resimden 1.
    • Once the back case is already off, use your fingers to lift up the circuit board from the side opposite the antenna.
  6. Midland X-tra Talk Radio LXT118 Front buttons Replacement: adım 6, 1 resimden 1.
    • Lay the circuit board down on the side, as you will not want it interfering with your work on the buttons!
  7. Midland X-tra Talk Radio LXT118 Front buttons Replacement: adım 7, 1 resimden 1.
    • Grasp the rubber cast around the buttons from one side, and slowly lift upwards. Make note of which way the buttons fit into the plastic casing!
    • At this point, the buttons can be cleaned in accordance with the radio buttons are stuck or sticking troubleshooting guide.
    • The speaker does not need to removed in order to get to the buttons.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Logan
282 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-43, Regan Winter 2013 Cal Poly, Team 19-43, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G43
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 1,041
