Ana içeriğe geç
Bu çeviri, kaynak kılavuzdaki en son güncellemeleri yansıtmayabilir. Çeviriyi güncellemeye yardımcı olun veya kaynak kılavuzunu görüntüleyin.
Miele S8340 Vacuum Disassembly
Neye ihtiyacın var
  1. Miele S8340 Vacuum Disassembly, Miele S8340 Vacuum Disassembly: adım 1, 2 resimden 1. Miele S8340 Vacuum Disassembly, Miele S8340 Vacuum Disassembly: adım 1, 2 resimden 2.
    • Open the vacuum and take out the dust bag.
  2. Miele S8340 Vacuum Disassembly: adım 2, 2 resimden 1. Miele S8340 Vacuum Disassembly: adım 2, 2 resimden 2.
    • Take out the filter.
    • Remove the screws.
  3. Miele S8340 Vacuum Disassembly: adım 3, 2 resimden 1. Miele S8340 Vacuum Disassembly: adım 3, 2 resimden 2.
    • Slide a flat object (like a flat head screwdriver or the spudger) underneath the buttons to remove them.
    • Remove the screws. For the left screw, you will need a screwdriver, an extension or something similar (the iFixit bit driver is not long enough).
  4. Miele S8340 Vacuum Disassembly: adım 4, 3 resimden 1. Miele S8340 Vacuum Disassembly: adım 4, 3 resimden 2. Miele S8340 Vacuum Disassembly: adım 4, 3 resimden 3.
    • The white cover and the black "ribbon" are secured with clips. To remove them, you first insert a spudger between the cover and the vacuum itself (picture 1). Then you can insert a spudger between the ribbon and the vacuum and slide it around the whole vacuum to detach the ribbon from the machine.
  5. Miele S8340 Vacuum Disassembly: adım 5, 3 resimden 1. Miele S8340 Vacuum Disassembly: adım 5, 3 resimden 2. Miele S8340 Vacuum Disassembly: adım 5, 3 resimden 3.
    • The white cover should now also be detached from the black ribbon.
    • To remove the cover, you need to slightly bend it outwards and then slide it over the hinge.
    • Be careful so you don't snap the cover.
    • After that you can remove the black ribbon.
  6. Miele S8340 Vacuum Disassembly: adım 6, 1 resimden 1.
    • The remove the vacuum pipe hooks you can remove this screw on both sides.
  7. Miele S8340 Vacuum Disassembly: adım 7, 1 resimden 1.
    • Next you will need to remove this screw, located left side of the motor
  8. Miele S8340 Vacuum Disassembly: adım 8, 3 resimden 1. Miele S8340 Vacuum Disassembly: adım 8, 3 resimden 2. Miele S8340 Vacuum Disassembly: adım 8, 3 resimden 3.
    • Now you can remove the whole rear part of the vacuum, together with the flap. You might need to pull on multiple places and use a bit of force.
    • After that part is removed there will be exposed live contacts. Definitely make sure that your vacuum is unplugged!
    • Now you can remove the plug from the motor and subsequently simply pull out the motor and the cable spool upwards. Make sure that you don't rip off any cables or connectors!
  9. Miele S8340 Vacuum Disassembly: adım 9, 1 resimden 1.
    • Then you can simply remove the black cover from the rear part of the vacuum by sliding it downwards.
  10. Miele S8340 Vacuum Disassembly: adım 10, 3 resimden 1. Miele S8340 Vacuum Disassembly: adım 10, 3 resimden 2. Miele S8340 Vacuum Disassembly: adım 10, 3 resimden 3.
    • Open this (and possibly further) clip on the rear part of the vacuum.
    • Then you can detach the part that contains the electronics from the flap.
    • This part houses the electronics. If you flip it around you can remove the circuit board easily.
Sonuç
Follow these instructions in reverse order to reassemble your device. There's one exception: Attach the black cover (step 9) to the part that houses the electronics first. Then attach that part to the flap (step 10). After that you can mount the whole thing to the vacuum.
Make sure that the two white connectors (see step 8 and 10) are aligned properly, so that they will connect again.
10 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
85%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Richard
1.077 İtibar
2 adet Kılavuz yazıldı
5Kılavuz Yorumları
Hi,
I found my Miele C3 just stopped working. this article:
https://howtofixit.net/miele-vacuum-not-...
suggested a common problem was that the electric cord pulls away from the contacts, which is exactly what had happened to my vacuum.
Your article has much better steps to disassemble the vacuum, you then need to solder the wires back on. Relatively simple.
Thanks.
Seb White - Yanıt
Hi Richard,
Ein Tipp: Eine wichtige Schraube ist in der Anleitung oben unerwähnt geblieben. Diese befindet sich unter dem Motorluft-Auslass, wenn man den Luftfilter entnimmt. Diese Schraube sollte ebenfalls im Schritt 7 und vor Schritt 8 entnommen werden.
Der richtige Zusammenbau war bei mir tricky: Das Hinterteil wird zuallererst von hinten unten hinter den rückseitigen Aufnahmekanal für den Saugschlauch geschoben. Dann wird die zusammengebaute Schaltereinheit mit Gefühl eingesetzt. Damit dabei die Tasten an der hinteren Kante des weißen Hauptdeckels vorbeipassen, muss der Deckel mehrfach vorsichtig auf- und zu bewegt werden. Dann klickt das Schalterteil irgendwann in die richtige Position. Hier nicht die Nerven verlieren (!) - Der Miele-Sauger ist hier wohl nicht mehr ganz so reparaturfreundlich wie noch bei meinem 728er-Modell von roundabout 2005, den ich vor ein paar Tagen restauriert hatte.
Cheers - Chris
Chris - Yanıt
Thanks a lot for the guide! My vacuum was making a lot of noise and heating up, cleaning the motor fixed all that, and saved me 300€ for buying a new one
Julien Ripet - Yanıt
Vielen Dank, das hat gut funktioniert. Ich finde, das Gerät ist gar nicht so schlecht konstruiert.
Marcus Röder - Yanıt
Vielen Dank für diese Anleitung! Wir hatten einen Kabelbruch, wo das Kabel auf die Aufrollautomatik gesteckt wird.
Super Anleitung, sehr hiflreich!
Holger Hinnendahl - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 gün: 69
Son 30 gün: 322
Her zaman: 24,464
