Ana içeriğe geç
Mill Cutter Paper Stripper Replacement
Takisha Parrish
Takisha Parrish ve başka bir katkıda bulunan
En son June 22, 2018 tarihinde güncellendi
55 dakika - 1 saat
Orta
I own an ID DEFENDER 10-sheet shredder that will go through the motions of shredding but the paper comes out wavy and not shredded. My guide will provide instructions to replace the mill cutter paper stripper and stripper guide so the shredder can shred paper correctly.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Mill Cutter Paper Stripper Replacement, Mill cutter paper stripper set and stripper guide set: adım 1, 1 resimden 1.
    • Unplug the shredder from the wall electrical outlet.
    • Remove the shredder from its catch basket and place it face down on a flat surface.
  2. Mill Cutter Paper Stripper Replacement: adım 2, 3 resimden 1. Mill Cutter Paper Stripper Replacement: adım 2, 3 resimden 2. Mill Cutter Paper Stripper Replacement: adım 2, 3 resimden 3.
    • Locate the seven case screws and remove them with a Phillips screwdriver. The screws are identified by the seven marked circles. The screws are 15 mm in length and the head diameter is 5 mm.
    • Remove the manufacturer’s label in order to get to one of the hidden screws, if applicable.
  3. Mill Cutter Paper Stripper Replacement: adım 3, 2 resimden 1. Mill Cutter Paper Stripper Replacement: adım 3, 2 resimden 2.
    • Remove the screws connecting the stripper guide and the base of the shredder's housing unit with a Phillips screwdriver. The diameter head and screws are 10 mm in length.
  4. Mill Cutter Paper Stripper Replacement: adım 4, 2 resimden 1. Mill Cutter Paper Stripper Replacement: adım 4, 2 resimden 2.
    • Once all of the screws have been removed, pull the casing apart.
    • Remove the stripper guide from the housing unit.
    • Use caution to prevent the trigger guard from falling apart.
  5. Mill Cutter Paper Stripper Replacement: adım 5, 3 resimden 1. Mill Cutter Paper Stripper Replacement: adım 5, 3 resimden 2. Mill Cutter Paper Stripper Replacement: adım 5, 3 resimden 3.
    • Remove the e-clips from the gears on the left side with a flathead screwdriver.
    • Remove screws from the gear box cover on the right side with a Phillips screwdriver. The screws are identified by the two marked circles. The screws are 7 mm in length and the head diameter is 3 mm.
  6. Mill Cutter Paper Stripper Replacement: adım 6, 3 resimden 1. Mill Cutter Paper Stripper Replacement: adım 6, 3 resimden 2. Mill Cutter Paper Stripper Replacement: adım 6, 3 resimden 3.
    • Remove the gears from both sides.
    • If the gears are hard to remove, use a flathead screwdriver to help remove them. The gears also may be greasy so place them on a paper towel or newspaper.
    • Remove the screws from the gearbox side plate with Phillips screwdriver to get to the gears. The screws are 7 mm in length and the head diameter is 3 mm.
  7. Mill Cutter Paper Stripper Replacement: adım 7, 2 resimden 1. Mill Cutter Paper Stripper Replacement: adım 7, 2 resimden 2.
    • Replace the mill cutter paper stripper set and stripper guide set.
    • Use protective gloves as the blades are very sharp.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Takisha Parrish
175 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 1,360
