Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement
Giriş
1. adıma gitThis guide will show you how to replace the diaphragm assembly. A faulty diaphragm assembly can lead to a few different issues including irregular shaking, grinding, or leaking grease.
Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
Remove the metal piston from the diaphragm assembly.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
to reasemble .
Which is the correct position of the Shift knob assembly ?
