Ana içeriğe geç
Milwaukee 6130-33 Fan Casing Replacement
Neye ihtiyacın var
  1. Milwaukee 6130-33 Fan Casing Replacement, Safety Brush Springs: adım 1, 3 resimden 1. Milwaukee 6130-33 Fan Casing Replacement, Safety Brush Springs: adım 1, 3 resimden 2. Milwaukee 6130-33 Fan Casing Replacement, Safety Brush Springs: adım 1, 3 resimden 3.
    • Remove both 3.5 mm TR10 Torx screws from the carbon brush locks.
    • Turn over the device and perform the same process on the opposite side.
  2. Milwaukee 6130-33 Fan Casing Replacement: adım 2, 2 resimden 1. Milwaukee 6130-33 Fan Casing Replacement: adım 2, 2 resimden 2.
    • Remove both springs by pulling outwards from the rotor.
    • When removing, pull on the carbon casing to avoid harming both yourself and the device.
  3. Milwaukee 6130-33 Fan Casing Replacement: adım 3, 2 resimden 1. Milwaukee 6130-33 Fan Casing Replacement: adım 3, 2 resimden 2.
    • Using a pair of pliers, squeeze the black cord.
    • Remove by pulling the black wire attached to the brush casing.
  4. Milwaukee 6130-33 Fan Casing Replacement, Fan Casing: adım 4, 2 resimden 1. Milwaukee 6130-33 Fan Casing Replacement, Fan Casing: adım 4, 2 resimden 2.
    • Remove the four 4 mm TR20 Torx screws from the gear casing.
  5. Milwaukee 6130-33 Fan Casing Replacement: adım 5, 2 resimden 1. Milwaukee 6130-33 Fan Casing Replacement: adım 5, 2 resimden 2.
    • Remove the case head attached to the rotor by pulling it up and off.
  6. Milwaukee 6130-33 Fan Casing Replacement: adım 6, 3 resimden 1. Milwaukee 6130-33 Fan Casing Replacement: adım 6, 3 resimden 2. Milwaukee 6130-33 Fan Casing Replacement: adım 6, 3 resimden 3.
    • Remove the four 3.5 mm TR10 Torx screws from the fan casing.
    • Remove the fan casing to access the inside casing.
Sonuç
Brandon Olguin
509 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 47
