Giriş
The trigger switch of the Milwaukee Circular Saw 263020 B57A 2008 is an external component that allows you to start the saw. If the trigger switch is broken or worn out because of excessive use, you can use this guide to replace the trigger switch. You can also use this troubleshooting page before continuing with replacement.
Neye ihtiyacın var
Remove the nine 6 mm screws using a Torx T4 screwdriver.
Remove the single 8 mm screw at the bottom that attaches the panels together using a Torx T6 screwdriver.
Slowly pull and remove the front panel of the saw that connects to the blade side with your hand, and separate it from the motor.
Remove four 10 mm screws that attach the wires to the trigger using a Phillips #2 screwdriver.
Gently move the wires from the trigger (the wires should just come off).
