Ana içeriğe geç
Milwaukee Hackzall 2625-20 Motor Replacement
Neye ihtiyacın var
  1. Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: adım 1, 2 resimden 1. Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: adım 1, 2 resimden 2.
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Motor Replacement, Electric Motor: adım 2, 1 resimden 1.
    • Find the red and black wire running from the back of the motor to the trigger mechanism.
    • With a soldering iron remove the two solders on the trigger mechanism.
  3. Milwaukee Hackzall 2625-20 Motor Replacement: adım 3, 2 resimden 1. Milwaukee Hackzall 2625-20 Motor Replacement: adım 3, 2 resimden 2.
    • Remove the two screws connecting the motor to the gear box with a T15 torx screwdriver.
    • The motor is now free and can be removed from the tool.
Sonuç
2 Yorum
Is there any chance to change only brushes in this motor?
Marcin Kędzior - Yanıt
That’s my exact question as well, nobody seems to cover this..
Anthony DeSanto - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 38
Her zaman: 2,320
