Ana içeriğe geç
Milwaukee Hackzall 2625-20 Terminal Block Replacement
Neye ihtiyacın var
  1. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Outer Casing: adım 1, 2 resimden 1. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Outer Casing: adım 1, 2 resimden 2.
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Terminal Block: adım 2, 1 resimden 1.
    • Carefully remove the terminal block from the casing and note that there is a spring set into it.
  3. Milwaukee Hackzall 2625-20 Terminal Block Replacement: adım 3, 2 resimden 1. Milwaukee Hackzall 2625-20 Terminal Block Replacement: adım 3, 2 resimden 2.
    • Use a soldering iron to melt any existing soldered attachments.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,439
