Ana içeriğe geç
Milwaukee Hackzall 2625-20 Trigger Replacement
Neye ihtiyacın var
  1. Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: adım 1, 2 resimden 1. Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: adım 1, 2 resimden 2.
    • Use a T9 Torx screwdriver to remove the one 7.0 mm screw.
    • Use a T10 Torx screwdriver to remove the one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight 16.0 mm screws.
    • Remove the casing to reveal the internal components.
  2. Milwaukee Hackzall 2625-20 Trigger Replacement: adım 2, 1 resimden 1.
    • Use a soldering iron to desolder the connections on the back of the trigger assembly.
    • Practice caution while soldering. Ensure proper safety and soldering procedure is followed to avoid component damage and injury.
    • For more information on soldering, check out this guide.
  3. Milwaukee Hackzall 2625-20 Trigger Replacement: adım 3, 2 resimden 1. Milwaukee Hackzall 2625-20 Trigger Replacement: adım 3, 2 resimden 2.
    • Remove the rest of the trigger assembly from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 1,699
