Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
As you begin this project, make sure to have a towel ready to clean the housing from obstructions that have entered the housing through use. Make sure to disconnect the trolling motor from any battery terminals. This repair is necessary to have a fully functional propeller. The tools needed are needle nose pliers or vice grips.
Neye ihtiyacın var
Clean the propeller and surrounding area so that you’re working with clean materials. This can also help loosen bolts, and make it easier to take apart.
Once you have the drive pin lined up correctly with the base of the propeller, repeat steps 1-3 in reverse order. Make sure to utilize your new parts such as the drive pin and lock washer if you purchased a propeller replacement kit to replace your old hardware.
2 farklı kişi bu kılavuzu tamamladı.
