Ana içeriğe geç
Minolta Dimage Xt Flash Capacitor Replacement
Neye ihtiyacın var
  1. Minolta Dimage Xt Flash Capacitor Replacement, Casing: adım 1, 3 resimden 1. Minolta Dimage Xt Flash Capacitor Replacement, Casing: adım 1, 3 resimden 2. Minolta Dimage Xt Flash Capacitor Replacement, Casing: adım 1, 3 resimden 3.
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Flash Capacitor Replacement: adım 2, 3 resimden 1. Minolta Dimage Xt Flash Capacitor Replacement: adım 2, 3 resimden 2. Minolta Dimage Xt Flash Capacitor Replacement: adım 2, 3 resimden 3.
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: adım 3, 2 resimden 1. Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: adım 3, 2 resimden 2.
    • Caution: Touching the capacitor leads may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • On the front side of the camera, locate the flash battery holder.
    • Lift the housing and remove the battery.
    • After removing the battery, clip the wires and solder the replacement battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Qqq
19 İtibar
1 Kılavuz yazıldı
Bir Yorum
Its a cap not a battery :D
Eigirdas Gedgaudas - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 992
