Ana içeriğe geç
Minolta X-700 Film Advance Lever Replacement
Neye ihtiyacın var
  1. Minolta X-700 Film Advance Lever Replacement, Film Advance Lever: adım 1, 3 resimden 1. Minolta X-700 Film Advance Lever Replacement, Film Advance Lever: adım 1, 3 resimden 2. Minolta X-700 Film Advance Lever Replacement, Film Advance Lever: adım 1, 3 resimden 3.
    • Using a Flathead screwdriver, remove the battery cap and then remove the battery.
    • Potential for device damage if you do not remove the battery prior to the repair.
  2. Minolta X-700 Film Advance Lever Replacement: adım 2, 3 resimden 1. Minolta X-700 Film Advance Lever Replacement: adım 2, 3 resimden 2. Minolta X-700 Film Advance Lever Replacement: adım 2, 3 resimden 3.
    • Using your hands unscrew the top of the film advance lever.
    • Afterward, you will be able to access the lever. Remove the lever by picking it up vertically.
  3. Minolta X-700 Film Advance Lever Replacement: adım 3, 3 resimden 1. Minolta X-700 Film Advance Lever Replacement: adım 3, 3 resimden 2. Minolta X-700 Film Advance Lever Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Microfiber Cleaning Cloths
    $3.99
    • Using a microfiber wipe, clean the gears with gear oil.
    • After oiling, place a new lever and top back the camera.
  4. Minolta X-700 Film Advance Lever Replacement: adım 4, 1 resimden 1.
    • Replace the battery and battery cover.
  5. Minolta X-700 Film Advance Lever Replacement: adım 5, 2 resimden 1. Minolta X-700 Film Advance Lever Replacement: adım 5, 2 resimden 2.
    • Test the lever.
Sonuç
christian Andre
121 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Unable to unscrew the top by hand
elena blaysorli - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 145
Her zaman: 4,394
