Ana içeriğe geç
Mizuno GFE1251 Baseball Glove Lacing Replacement
Chandler Torres
Chandler Torres ve 3 diğer katkıda bulunanlar
En son June 24, 2024 tarihinde güncellendi
40 dakika - 2 saat
Orta
Daha iyi giriş
Neye ihtiyacın var
  1. Mizuno GFE1251 Baseball Glove Lacing Replacement, Lacing: adım 1, 1 resimden 1.
    • Untie the knot 1.
    • If you are having trouble, you can cut it with scissors.
  2. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 2, 1 resimden 1.
    • From where the knot was, start unweaving the lacing.
    • To unweave the lacing, pull it through all of the holes, until you get to the next section.
    • The lacing is hard to pull through the glove and requires quite a bit of manpower.
    • The first section continues up until the pocket.
  3. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 3, 3 resimden 1. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 3, 3 resimden 2. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 3, 3 resimden 3.
    • This section is difficult to unlace and may need the assistance of a tool to get it lose. We have used the unlacing/lacing tool that came with the our kit.
    • This is the pocket section.
  4. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 4, 3 resimden 1. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 4, 3 resimden 2. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 4, 3 resimden 3.
    • Trace along the pocket and when you come to the end untie the knot.
    • We have now unlaced all of the glove.
  5. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 5, 3 resimden 1. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 5, 3 resimden 2. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 5, 3 resimden 3.
    • Start by weaving the lace through the lacing tool as shown.
    • Weave through spot A and then tie a knot.
    • Weave the lace through the pattern shown
  6. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 6, 3 resimden 1. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 6, 3 resimden 2. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 6, 3 resimden 3.
    • Weave the lace through spot B.
    • Follow the pattern shown and tie a knot at spot C.
    • Make sure to pull this section tighter than the rest.
    • Cut off the extra lace.
    • We have now used the first length of lace.
  7. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 7, 3 resimden 1. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 7, 3 resimden 2. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 7, 3 resimden 3.
    • Weave through spot D and then tie a knot.
    • Follow the pattern shown.
  8. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 8, 3 resimden 1. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 8, 3 resimden 2. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 8, 3 resimden 3.
    • Tie a knot at spot E and cut off the left over lace.
    • We will be using this lace in the next step.
  9. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 9, 3 resimden 1. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 9, 3 resimden 2. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 9, 3 resimden 3.
    • Weave through spot F and tie a knot.
    • Weave through spot G and tie a knot.
    • Spot G has another piece of lace in it but it opens up in two different spots.
  10. Mizuno GFE1251 Baseball Glove Lacing Replacement: adım 10, 1 resimden 1.
    • Congratulations, you now have relaced your old baseball glove!
Sonuç
Enjoy your newly-repaired baseball glove.
Chandler Torres
101 İtibar
1 Kılavuz yazıldı
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 20
Son 30 gün: 76
Her zaman: 4,364
