Ana içeriğe geç
Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement
  1. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade Cover: adım 1, 3 resimden 1. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade Cover: adım 1, 3 resimden 2. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade Cover: adım 1, 3 resimden 3.
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • If the clear water pump hose is connected, remove it now.
    • Loosen the plastic knob holding the saw's cutting head in place.
    • Lower the cutting head while keeping it steady.
  2. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 2, 2 resimden 1. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 2, 2 resimden 2.
    • Unscrew the knob.
    • Remove it from the cutting head.
  3. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 3, 2 resimden 1. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 3, 2 resimden 2.
    • Loosen the plastic knob holding the blade cover in place.
  4. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 4, 3 resimden 1. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 4, 3 resimden 2. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 4, 3 resimden 3.
    • Loosen the wing nut on the blade cover pivot shaft.
    • Remove the wing nut and accompanying washer.
  5. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 5, 2 resimden 1. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 5, 2 resimden 2.
    • Pivot the blade cover up and pull it off the shaft.
  6. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade: adım 6, 3 resimden 1. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade: adım 6, 3 resimden 2. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade: adım 6, 3 resimden 3.
    • Insert the provided spanner wrench into one of the four tightening holes on the inner flange behind the blade.
    • Use the the provided nut wrench to loosen the hex nut while providing counterforce with the spanner wrench.
  7. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 7, 2 resimden 1. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 7, 2 resimden 2.
    • Remove the hex nut.
    • Remove the outer flange.
  8. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 8, 2 resimden 1. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: adım 8, 2 resimden 2.
    • Remove the cutting blade.
    • The blade can be sharp, so handle with care.
  9. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Cutting Head: adım 9, 3 resimden 1. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Cutting Head: adım 9, 3 resimden 2. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Cutting Head: adım 9, 3 resimden 3.
    • Pull the entire cutting head straight off the shaft holding it in place.
Sonuç
Carsten Frauenheim
113.712 İtibar
338 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 121
