Ana içeriğe geç
Modal MD-WORCSS6 LED Replacement
Neye ihtiyacın var
  1. Modal MD-WORCSS6 LED Replacement, Modal MD-WORCSS6 Teardown Guide: adım 1, 2 resimden 1. Modal MD-WORCSS6 LED Replacement, Modal MD-WORCSS6 Teardown Guide: adım 1, 2 resimden 2.
    • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
    • Using the jimmy tool, carefully pry off the black plastic ring.
    • Remove the spring assembly from inside the transparent plastic tube.
    FixBot'a Sor
    Yorum Ekle
  2. Modal MD-WORCSS6 LED Replacement: adım 2, 2 resimden 1. Modal MD-WORCSS6 LED Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
    • Take the plastic tube off of the metal casing.
    FixBot'a Sor
    Yorum Ekle
  3. Modal MD-WORCSS6 LED Replacement: adım 3, 2 resimden 1. Modal MD-WORCSS6 LED Replacement: adım 3, 2 resimden 2.
    • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
    • With the button assembly removed, slide off the metal casing.
    FixBot'a Sor
    Yorum Ekle
  4. Modal MD-WORCSS6 LED Replacement: adım 4, 3 resimden 1. Modal MD-WORCSS6 LED Replacement: adım 4, 3 resimden 2. Modal MD-WORCSS6 LED Replacement: adım 4, 3 resimden 3.
    • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
    • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
    FixBot'a Sor
    Yorum Ekle
  5. Modal MD-WORCSS6 LED Replacement: adım 5, 3 resimden 1. Modal MD-WORCSS6 LED Replacement: adım 5, 3 resimden 2. Modal MD-WORCSS6 LED Replacement: adım 5, 3 resimden 3.
    • Carefully peel the tape off far enough to remove the 3 batteries.
    FixBot'a Sor
    Yorum Ekle
  6. Modal MD-WORCSS6 LED Replacement, LED: adım 6, 3 resimden 1. Modal MD-WORCSS6 LED Replacement, LED: adım 6, 3 resimden 2. Modal MD-WORCSS6 LED Replacement, LED: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Slide the circuit board out of its slot.
    • Remove the LEDs by clipping off their connections with a pair of tweezers.
    • Attach the new LEDs by soldering the ends of the LEDS to their corresponding connections on the circuit board.
    • Check out our How to Solder and Desolder Connections guide for best practices and soldering tips.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 296
