Ana içeriğe geç
Modal MD-WORCSS6 Motor Replacement
Neye ihtiyacın var
  1. Modal MD-WORCSS6 Motor Replacement, Modal MD-WORCSS6 Teardown Guide: adım 1, 2 resimden 1. Modal MD-WORCSS6 Motor Replacement, Modal MD-WORCSS6 Teardown Guide: adım 1, 2 resimden 2.
    • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
    • Using the jimmy tool, carefully pry off the black plastic ring.
    • Remove the spring assembly from inside the transparent plastic tube.
  2. Modal MD-WORCSS6 Motor Replacement: adım 2, 2 resimden 1. Modal MD-WORCSS6 Motor Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
    • Take the plastic tube off of the metal casing.
  3. Modal MD-WORCSS6 Motor Replacement: adım 3, 2 resimden 1. Modal MD-WORCSS6 Motor Replacement: adım 3, 2 resimden 2.
    • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
    • With the button assembly removed, slide off the metal casing.
  4. Modal MD-WORCSS6 Motor Replacement: adım 4, 3 resimden 1. Modal MD-WORCSS6 Motor Replacement: adım 4, 3 resimden 2. Modal MD-WORCSS6 Motor Replacement: adım 4, 3 resimden 3.
    • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
    • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
  5. Modal MD-WORCSS6 Motor Replacement: adım 5, 3 resimden 1. Modal MD-WORCSS6 Motor Replacement: adım 5, 3 resimden 2. Modal MD-WORCSS6 Motor Replacement: adım 5, 3 resimden 3.
    • Carefully peel the tape off far enough to remove the 3 batteries.
  6. Modal MD-WORCSS6 Motor Replacement, Motor: adım 6, 3 resimden 1. Modal MD-WORCSS6 Motor Replacement, Motor: adım 6, 3 resimden 2. Modal MD-WORCSS6 Motor Replacement, Motor: adım 6, 3 resimden 3.
    • Slide the circuit board out of its slot.
    • Pull the white plastic neck down and out of the slot. Remove the neck and body spring.
  7. Modal MD-WORCSS6 Motor Replacement: adım 7, 1 resimden 1.
    • Use wire cutters to cut the wires connected to the bottom of the motor.
    • Remove the motor from the plastic body.
  8. Modal MD-WORCSS6 Motor Replacement: adım 8, 1 resimden 1.
    • Strip the insulation from the wire up to about half an inch from the end of the exposed wire.
    • Attach a new motor to the device by re-soldering the connections that were cut earlier.
    • Check out our How to Solder and Desolder Connections guide for best practices and soldering tips.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 77
