Ana içeriğe geç
Modal MD-WORCSS6 Motor Replacement
Neye ihtiyacın var
    1. Modal MD-WORCSS6 Motor Replacement, Modal MD-WORCSS6 Teardown Guide: adım 1, 2 resimden 1. Modal MD-WORCSS6 Motor Replacement, Modal MD-WORCSS6 Teardown Guide: adım 1, 2 resimden 2.
      • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
      • Using the jimmy tool, carefully pry off the black plastic ring.
      • Remove the spring assembly from inside the transparent plastic tube.
      FixBot'a Sor
      Yorum Ekle
    2. Modal MD-WORCSS6 Motor Replacement: adım 2, 2 resimden 1. Modal MD-WORCSS6 Motor Replacement: adım 2, 2 resimden 2.
      • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
      • Take the plastic tube off of the metal casing.
      FixBot'a Sor
      Yorum Ekle
    3. Modal MD-WORCSS6 Motor Replacement: adım 3, 2 resimden 1. Modal MD-WORCSS6 Motor Replacement: adım 3, 2 resimden 2.
      • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
      • With the button assembly removed, slide off the metal casing.
      FixBot'a Sor
      Yorum Ekle
    4. Modal MD-WORCSS6 Motor Replacement: adım 4, 3 resimden 1. Modal MD-WORCSS6 Motor Replacement: adım 4, 3 resimden 2. Modal MD-WORCSS6 Motor Replacement: adım 4, 3 resimden 3.
      • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
      • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
      FixBot'a Sor
      Yorum Ekle
    5. Modal MD-WORCSS6 Motor Replacement: adım 5, 3 resimden 1. Modal MD-WORCSS6 Motor Replacement: adım 5, 3 resimden 2. Modal MD-WORCSS6 Motor Replacement: adım 5, 3 resimden 3.
      • Carefully peel the tape off far enough to remove the 3 batteries.
      FixBot'a Sor
      Yorum Ekle
    1. Modal MD-WORCSS6 Motor Replacement, Motor: adım 6, 3 resimden 1. Modal MD-WORCSS6 Motor Replacement, Motor: adım 6, 3 resimden 2. Modal MD-WORCSS6 Motor Replacement, Motor: adım 6, 3 resimden 3.
      • Slide the circuit board out of its slot.
      • Pull the white plastic neck down and out of the slot. Remove the neck and body spring.
      FixBot'a Sor
      Yorum Ekle
    2. Modal MD-WORCSS6 Motor Replacement: adım 7, 1 resimden 1.
      • Use wire cutters to cut the wires connected to the bottom of the motor.
      • Remove the motor from the plastic body.
      FixBot'a Sor
      Yorum Ekle
    3. Modal MD-WORCSS6 Motor Replacement: adım 8, 1 resimden 1.
      • Strip the insulation from the wire up to about half an inch from the end of the exposed wire.
      • Attach a new motor to the device by re-soldering the connections that were cut earlier.
      • Check out our How to Solder and Desolder Connections guide for best practices and soldering tips.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 370
