Ana içeriğe geç
Motherboard Replacement
Neye ihtiyacın var
    1. Motherboard Replacement, Fellowes T7CM Casing and Trigger Replacement: adım 1, 1 resimden 1.
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      FixBot'a Sor
      Yorum Ekle
    2. Motherboard Replacement: adım 2, 1 resimden 1.
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      FixBot'a Sor
      Yorum Ekle
    3. Motherboard Replacement: adım 3, 1 resimden 1.
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      FixBot'a Sor
      Yorum Ekle
    4. Motherboard Replacement: adım 4, 1 resimden 1.
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      FixBot'a Sor
      Yorum Ekle
    1. Motherboard Replacement, On,  Off, Reverse Switch: adım 5, 1 resimden 1.
      • Unscrew both of the screws from the circuit board of the switch . Lift the circuit board away from the device. The screw length is 10 mm and the head diameter is 6 mm.
      FixBot'a Sor
      Yorum Ekle
    2. Motherboard Replacement: adım 6, 2 resimden 1. Motherboard Replacement: adım 6, 2 resimden 2.
      • Remove the plastic switch case.
      • After the plastic case is removed, the switch can be replaced.
      • During the switch replacement, be careful of the springs that are held in side. They can potentially come loose and get lost.
      FixBot'a Sor
      Yorum Ekle
    1. Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
      • Desolder the wires from the motherboard. Learn more about soldering componentshere!
      FixBot'a Sor
      Yorum Ekle
    2. Motherboard Replacement: adım 8, 1 resimden 1.
      • After all of the wires are removed, the motherboard can be lifted off and removed with ease.
      FixBot'a Sor
      Yorum Ekle
Sonuç
John Wisthoff
487 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S2G2
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 1,270
