Ana içeriğe geç
Motherboard Replacement
Neye ihtiyacın var
  1. Motherboard Replacement, Back Cover: adım 1, 3 resimden 1. Motherboard Replacement, Back Cover: adım 1, 3 resimden 2. Motherboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Motherboard Replacement: adım 2, 1 resimden 1.
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Motherboard Replacement, Battery: adım 3, 1 resimden 1.
    • Remove masking tape from the battery.
  4. Motherboard Replacement: adım 4, 3 resimden 1. Motherboard Replacement: adım 4, 3 resimden 2. Motherboard Replacement: adım 4, 3 resimden 3.
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Motherboard Replacement: adım 5, 3 resimden 1. Motherboard Replacement: adım 5, 3 resimden 2. Motherboard Replacement: adım 5, 3 resimden 3.
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. How To Solder and Desolder Connections
    • Use caution when operating the soldering iron.
  6. Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
    • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
    • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
  7. Motherboard Replacement: adım 7, 1 resimden 1.
    • Use the nut driver and J00 bit to remove the three 4 mm screws.
  8. Motherboard Replacement: adım 8, 3 resimden 1. Motherboard Replacement: adım 8, 3 resimden 2. Motherboard Replacement: adım 8, 3 resimden 3.
    • Peel back metal tape that is hiding the auxiliary port wires.
    • Remove tape that is holding the speaker wires in place.
    • Lift up on the motherboard to release it from the tablet.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Connor Fisher
212 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 4-1, Williams Fall 2016 Baylor, Team 4-1, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S4G1
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 290
