Ana içeriğe geç
Moto C Plus Screen Assembly Replacement
Neye ihtiyacın var
  1. Moto C Plus Screen Assembly Replacement, Back Cover: adım 1, 3 resimden 1. Moto C Plus Screen Assembly Replacement, Back Cover: adım 1, 3 resimden 2. Moto C Plus Screen Assembly Replacement, Back Cover: adım 1, 3 resimden 3.
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
    • Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
    FixBot'a Sor
    Yorum Ekle
  2. Moto C Plus Screen Assembly Replacement: adım 2, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 2, 2 resimden 2.
    • Lift the phone out of the back cover.
    FixBot'a Sor
    Yorum Ekle
  3. Moto C Plus Screen Assembly Replacement, Battery: adım 3, 3 resimden 1. Moto C Plus Screen Assembly Replacement, Battery: adım 3, 3 resimden 2. Moto C Plus Screen Assembly Replacement, Battery: adım 3, 3 resimden 3.
    • Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
    • Lever the battery out of its recess and remove it.
    FixBot'a Sor
    Yorum Ekle
  4. Moto C Plus Screen Assembly Replacement, Daughterboard Cover: adım 4, 1 resimden 1.
    • Remove the six 3.1 mm Phillips #00 screws securing the daughterboard cover.
    FixBot'a Sor
    Yorum Ekle
  5. Moto C Plus Screen Assembly Replacement: adım 5, 3 resimden 1. Moto C Plus Screen Assembly Replacement: adım 5, 3 resimden 2. Moto C Plus Screen Assembly Replacement: adım 5, 3 resimden 3.
    • Apply a spudger to the right side of the daughterboard cover.
    • Twist the spudger sideways to pry up the daughterboard cover until you get a good grip.
    • Remove the daughterboard cover.
    FixBot'a Sor
    Yorum Ekle
  6. Moto C Plus Screen Assembly Replacement, Motherboard Cover: adım 6, 1 resimden 1.
    • Remove the five 3.1 mm long Phillips #00 screws.
    FixBot'a Sor
    Yorum Ekle
  7. Moto C Plus Screen Assembly Replacement: adım 7, 3 resimden 1. Moto C Plus Screen Assembly Replacement: adım 7, 3 resimden 2. Moto C Plus Screen Assembly Replacement: adım 7, 3 resimden 3.
    • Apply an opening pick to the bottom right corner of the motherboard cover.
    • Twist the opening pick to free the motherboard cover out of the plastic clamps on the right side of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Moto C Plus Screen Assembly Replacement: adım 8, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 8, 2 resimden 2.
    • Repeat the previous step on the left side of the motherboard cover to free it out of the plastic clamps.
    • Pry up the motherboard cover until you can get a good grip.
    • Remove the motherboard cover.
    FixBot'a Sor
    Yorum Ekle
  9. Moto C Plus Screen Assembly Replacement, Motherboard Assembly: adım 9, 1 resimden 1.
    • Remove the two 3.2 mm Phillips #00 screws securing the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. Moto C Plus Screen Assembly Replacement: adım 10, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 10, 2 resimden 2.
    • Use the tip of a spudger to lift the latch on the power and volume button ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  11. Moto C Plus Screen Assembly Replacement: adım 11, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 11, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • Fold the power and volume button flex cable out of the way.
    FixBot'a Sor
    Yorum Ekle
  12. Moto C Plus Screen Assembly Replacement: adım 12, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 12, 2 resimden 2.
    • Pry up and disconnect the antenna cable.
    • Fold the antenna cable out of the way.
    FixBot'a Sor
    Yorum Ekle
  13. Moto C Plus Screen Assembly Replacement: adım 13, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 13, 2 resimden 2.
    • Use the tip of a spudger to open the interconnect cable ZIF connector by lifting the brown flap.
    • When reassembling make sure the white line on the cable aligns with the closed flap.
    FixBot'a Sor
    Yorum Ekle
  14. Moto C Plus Screen Assembly Replacement: adım 14, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 14, 2 resimden 2.
    • Use a pair of tweezers to pull the interconnect flex cable out of the ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  15. Moto C Plus Screen Assembly Replacement: adım 15, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 15, 2 resimden 2.
    • Use the tip of a spudger to open the flap of the ZIF connector next to the headphone jack.
    FixBot'a Sor
    Yorum Ekle
  16. Moto C Plus Screen Assembly Replacement: adım 16, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 16, 2 resimden 2.
    • Use a pair of tweezers to pull the flex cable out of the ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  17. Moto C Plus Screen Assembly Replacement: adım 17, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 17, 2 resimden 2.
    • Don't try to remove the motherboard all the way yet. The display flex cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
    • Lift the motherboard and fold it back until you have enough space to disconnect the display flex cable.
    FixBot'a Sor
    Yorum Ekle
  18. Moto C Plus Screen Assembly Replacement: adım 18, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 18, 2 resimden 2.
    • Use the edge of a spudger to pry up and disconnect the display flex cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  19. Moto C Plus Screen Assembly Replacement: adım 19, 1 resimden 1.
    • Remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
  20. Moto C Plus Screen Assembly Replacement, Daughterboard: adım 20, 2 resimden 1. Moto C Plus Screen Assembly Replacement, Daughterboard: adım 20, 2 resimden 2.
    • Disconnect the antenna cable and fold it out of the way.
    FixBot'a Sor
    Yorum Ekle
  21. Moto C Plus Screen Assembly Replacement: adım 21, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 21, 2 resimden 2.
    • Use the tip of a spudger to open the brown flap of the ZIF connector that holds the interconnect cable in its place.
    FixBot'a Sor
    Yorum Ekle
  22. Moto C Plus Screen Assembly Replacement: adım 22, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 22, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  23. Moto C Plus Screen Assembly Replacement: adım 23, 1 resimden 1.
    • Prepare an iOpener and apply it to the bottom part of the display for at least two minutes to loosen the adhesive beneath the daughterboard.
    FixBot'a Sor
    Yorum Ekle
  24. Moto C Plus Screen Assembly Replacement: adım 24, 3 resimden 1. Moto C Plus Screen Assembly Replacement: adım 24, 3 resimden 2. Moto C Plus Screen Assembly Replacement: adım 24, 3 resimden 3.
    • Apply an opening pick to the bottom edge of the daughterboard.
    • Carefully slide the opening pick under the daughterboard to cut the adhesive underneath.
    • Take care to cut the adhesive underneath the vibration motor.
    • Slide the opening pick from right to left to cut all the adhesive.
    FixBot'a Sor
    Yorum Ekle
  25. Moto C Plus Screen Assembly Replacement: adım 25, 1 resimden 1.
    • Remove the daughterboard including the soldered-on vibration motor.
    FixBot'a Sor
    Yorum Ekle
  26. Moto C Plus Screen Assembly Replacement, Earpiece Speaker: adım 26, 1 resimden 1.
    • Use an iOpener and apply it to the top edge of the display to loosen the adhesive beneath the earpiece speaker.
    FixBot'a Sor
    Yorum Ekle
  27. Moto C Plus Screen Assembly Replacement: adım 27, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 27, 2 resimden 2.
    • Use a pair of tweezers to carefully grab and remove the earpiece speaker.
    FixBot'a Sor
    Yorum Ekle
  28. Moto C Plus Screen Assembly Replacement, Screen Assembly: adım 28, 2 resimden 1. Moto C Plus Screen Assembly Replacement, Screen Assembly: adım 28, 2 resimden 2.
    • Use a pair of tweezers to remove the rubber headphone jack gasket in the corner of the display assembly.
    FixBot'a Sor
    Yorum Ekle
  29. Moto C Plus Screen Assembly Replacement: adım 29, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 29, 2 resimden 2.
    • Use a pair of tweezers to remove the rubber charging port gasket.
    FixBot'a Sor
    Yorum Ekle
  30. Moto C Plus Screen Assembly Replacement: adım 30, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 30, 2 resimden 2.
    • Use a pair of tweezers to grab and remove the microphone rubber gasket at the bottom right end of your phone.
    FixBot'a Sor
    Yorum Ekle
  31. Moto C Plus Screen Assembly Replacement: adım 31, 1 resimden 1.
    • Use an iOpener to loosen the adhesive tape that sits on top of the interconnect and display flex cable. Apply the iOpener on the tape for at least two minutes.
    FixBot'a Sor
    Yorum Ekle
  32. Moto C Plus Screen Assembly Replacement: adım 32, 3 resimden 1. Moto C Plus Screen Assembly Replacement: adım 32, 3 resimden 2. Moto C Plus Screen Assembly Replacement: adım 32, 3 resimden 3.
    • Use a pair of tweezers to gently peel the adhesive tape off the flex cables and fold it out of the way.
    FixBot'a Sor
    Yorum Ekle
  33. Moto C Plus Screen Assembly Replacement: adım 33, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 33, 2 resimden 2.
    • Use a pair of tweezers to gently peel the product sticker off the interconnect cable.
    • In case you can't remove the sticker or it starts to rip apart you can re-apply an iOpener to loosen the adhesive.
    FixBot'a Sor
    Yorum Ekle
  34. Moto C Plus Screen Assembly Replacement: adım 34, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 34, 2 resimden 2.
    • Use a pair of tweezers to grab and carefully peel up the interconnect flex cable.
    • Remove the interconnect flex cable.
    FixBot'a Sor
    Yorum Ekle
  35. Moto C Plus Screen Assembly Replacement: adım 35, 2 resimden 1. Moto C Plus Screen Assembly Replacement: adım 35, 2 resimden 2.
    • Use a pair of tweezers to remove the antenna cable.
    FixBot'a Sor
    Yorum Ekle
  36. Moto C Plus Screen Assembly Replacement: adım 36, 1 resimden 1.
    • Check your replacement part for any other components that need to be transferred before reassembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
261.711 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.535 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 2,801
