Ana içeriğe geç
Moto C Screen Assembly Replacement
Neye ihtiyacın var
  1. Moto C Screen Assembly Replacement, Back Cover: adım 1, 3 resimden 1. Moto C Screen Assembly Replacement, Back Cover: adım 1, 3 resimden 2. Moto C Screen Assembly Replacement, Back Cover: adım 1, 3 resimden 3.
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
    • Move it to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
    FixBot'a Sor
    Yorum Ekle
  2. Moto C Screen Assembly Replacement: adım 2, 2 resimden 1. Moto C Screen Assembly Replacement: adım 2, 2 resimden 2.
    • Lift the phone out of the back cover.
    FixBot'a Sor
    Yorum Ekle
  3. Moto C Screen Assembly Replacement, Battery: adım 3, 3 resimden 1. Moto C Screen Assembly Replacement, Battery: adım 3, 3 resimden 2. Moto C Screen Assembly Replacement, Battery: adım 3, 3 resimden 3.
    • Use a finger or spudger to lever the battery out of its recess and remove it.
    FixBot'a Sor
    Yorum Ekle
  4. Moto C Screen Assembly Replacement, Motherboard Cover: adım 4, 1 resimden 1.
    • Remove the six 3.5 mm long Torx T5 screws.
    FixBot'a Sor
    Yorum Ekle
  5. Moto C Screen Assembly Replacement: adım 5, 2 resimden 1. Moto C Screen Assembly Replacement: adım 5, 2 resimden 2.
    • Insert an opening pick between the cover and the motherboard near the SIM 2 slot where the power buttons are located.
    • Slide and twist the opening pick to pry open the plastic clips securing the cover.
    FixBot'a Sor
    Yorum Ekle
  6. Moto C Screen Assembly Replacement: adım 6, 2 resimden 1. Moto C Screen Assembly Replacement: adım 6, 2 resimden 2.
    • Slide an opening pick between the cover and the motherboard on the opposite side next to the SD card slot.
    • Twist the opening pick to pry open the plastic clips securing the cover.
    FixBot'a Sor
    Yorum Ekle
  7. Moto C Screen Assembly Replacement: adım 7, 2 resimden 1. Moto C Screen Assembly Replacement: adım 7, 2 resimden 2.
    • Remove the motherboard cover.
    FixBot'a Sor
    Yorum Ekle
  8. Moto C Screen Assembly Replacement, Daughterboard Cover: adım 8, 1 resimden 1.
    • Remove the four 3.5 mm long Torx T5 screws.
    • Some screws might be covered with stickers.
    FixBot'a Sor
    Yorum Ekle
  9. Moto C Screen Assembly Replacement: adım 9, 3 resimden 1. Moto C Screen Assembly Replacement: adım 9, 3 resimden 2. Moto C Screen Assembly Replacement: adım 9, 3 resimden 3.
    • Apply the edge of an opening pick to the bottom right corner under the daughterboard cover.
    • Twist the opening pick to open the plastic clamps of the daughterboard cover.
    • Slide the opening pick to the left and pry it upwards until you can get a good grip on the daughterboard cover.
    FixBot'a Sor
    Yorum Ekle
  10. Moto C Screen Assembly Replacement: adım 10, 1 resimden 1.
    • Remove the daughterboard cover.
    FixBot'a Sor
    Yorum Ekle
  11. Moto C Screen Assembly Replacement, Motherboard Assembly: adım 11, 1 resimden 1.
    • Remove the three 2.5 mm long T5 Torx screws.
    FixBot'a Sor
    Yorum Ekle
  12. Moto C Screen Assembly Replacement: adım 12, 2 resimden 1. Moto C Screen Assembly Replacement: adım 12, 2 resimden 2.
    • Use the tip of an opening pick to pry up and open the black lever of the ZIF connector located on the bottom left of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  13. Moto C Screen Assembly Replacement: adım 13, 2 resimden 1. Moto C Screen Assembly Replacement: adım 13, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • Fold the power and volume button flex cable out of the way.
    FixBot'a Sor
    Yorum Ekle
  14. Moto C Screen Assembly Replacement: adım 14, 2 resimden 1. Moto C Screen Assembly Replacement: adım 14, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the display flex cable located at the bottom of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  15. Moto C Screen Assembly Replacement: adım 15, 2 resimden 1. Moto C Screen Assembly Replacement: adım 15, 2 resimden 2.
    • Use the tip of an opening pick to pry up and open the black lever of the ZIF connector located at the top of the motherboard next to the rear camera.
    FixBot'a Sor
    Yorum Ekle
  16. Moto C Screen Assembly Replacement: adım 16, 2 resimden 1. Moto C Screen Assembly Replacement: adım 16, 2 resimden 2.
    • Use a pair of tweezers to pull the digitizer flex cable out of the ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  17. Moto C Screen Assembly Replacement: adım 17, 1 resimden 1.
    • Prepare an iOpener and apply it to the upper half of the display for at least two minutes to loosen the adhesive beneath the vibration motor and the rear facing camera.
    FixBot'a Sor
    Yorum Ekle
  18. Moto C Screen Assembly Replacement: adım 18, 2 resimden 1. Moto C Screen Assembly Replacement: adım 18, 2 resimden 2.
    • Don't try to remove the motherboard all the way yet. The antenna cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  19. Moto C Screen Assembly Replacement: adım 19, 3 resimden 1. Moto C Screen Assembly Replacement: adım 19, 3 resimden 2. Moto C Screen Assembly Replacement: adım 19, 3 resimden 3.
    • Fold the motherboard over the battery cavity to access the coaxial cable connectors.
    FixBot'a Sor
    Yorum Ekle
  20. Moto C Screen Assembly Replacement: adım 20, 2 resimden 1. Moto C Screen Assembly Replacement: adım 20, 2 resimden 2.
    • Use a pair of tweezers to pry up and disconnect the antenna cable from the back of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  21. Moto C Screen Assembly Replacement: adım 21, 1 resimden 1.
    • Remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
  22. Moto C Screen Assembly Replacement, Daughterboard: adım 22, 2 resimden 1. Moto C Screen Assembly Replacement, Daughterboard: adım 22, 2 resimden 2.
    • Use a pair of tweezers to disconnect the antenna cable on the left of the daughterboard.
    FixBot'a Sor
    Yorum Ekle
  23. Moto C Screen Assembly Replacement: adım 23, 2 resimden 1. Moto C Screen Assembly Replacement: adım 23, 2 resimden 2.
    • Use a spudger to disconnect the digitizer flex cable on the upper left of the daughterboard.
    FixBot'a Sor
    Yorum Ekle
  24. Moto C Screen Assembly Replacement: adım 24, 2 resimden 1. Moto C Screen Assembly Replacement: adım 24, 2 resimden 2.
    • Use a pair of tweezers to remove the rubber gasket that covers the microphone on the bottom right of the daughterboard.
    FixBot'a Sor
    Yorum Ekle
  25. Moto C Screen Assembly Replacement: adım 25, 1 resimden 1.
    • Prepare an iOpener and apply it to the bottom part of the display for at least two minutes to loosen the adhesive beneath the daughterboard.
    FixBot'a Sor
    Yorum Ekle
  26. Moto C Screen Assembly Replacement: adım 26, 3 resimden 1. Moto C Screen Assembly Replacement: adım 26, 3 resimden 2. Moto C Screen Assembly Replacement: adım 26, 3 resimden 3.
    • Apply an opening pick to the bottom right corner of the daughterboard.
    • Carefully slide the opening pick under the daughterboard to cut the adhesive underneath.
    • Slide the opening pick from right to left to cut all the adhesive.
    FixBot'a Sor
    Yorum Ekle
  27. Moto C Screen Assembly Replacement: adım 27, 2 resimden 1. Moto C Screen Assembly Replacement: adım 27, 2 resimden 2.
    • Twist the opening pick to lift the daughterboard until you can get a good grip.
    • Remove the daughterboard.
    FixBot'a Sor
    Yorum Ekle
  28. Moto C Screen Assembly Replacement, Earpiece Speaker: adım 28, 2 resimden 1. Moto C Screen Assembly Replacement, Earpiece Speaker: adım 28, 2 resimden 2.
    • Remove the ear piece speaker.
    • When reassembling, be sure to properly orient the earpiece speaker such that the gold contacts are pointing away from the top edge.
    FixBot'a Sor
    Yorum Ekle
  29. Moto C Screen Assembly Replacement, Screen Assembly: adım 29, 2 resimden 1. Moto C Screen Assembly Replacement, Screen Assembly: adım 29, 2 resimden 2.
    • Use a pair of tweezers to grab and remove the charging port rubber gasket.
    FixBot'a Sor
    Yorum Ekle
  30. Moto C Screen Assembly Replacement: adım 30, 3 resimden 1. Moto C Screen Assembly Replacement: adım 30, 3 resimden 2. Moto C Screen Assembly Replacement: adım 30, 3 resimden 3.
    • Use a pair of tweezers to gently peel off and remove the power and volume buttons.
    FixBot'a Sor
    Yorum Ekle
  31. Moto C Screen Assembly Replacement: adım 31, 1 resimden 1.
    • Prepare an iOpener and apply it for at least two minutes on the back of the phone to loosen the adhesive tape that sits on top of the display flex cable.
    FixBot'a Sor
    Yorum Ekle
  32. Moto C Screen Assembly Replacement: adım 32, 3 resimden 1. Moto C Screen Assembly Replacement: adım 32, 3 resimden 2. Moto C Screen Assembly Replacement: adım 32, 3 resimden 3.
    • Use a pair of tweezers to peel the adhesive tape off the left side where the antenna cable runs and fold it out of the way.
    FixBot'a Sor
    Yorum Ekle
  33. Moto C Screen Assembly Replacement: adım 33, 3 resimden 1. Moto C Screen Assembly Replacement: adım 33, 3 resimden 2. Moto C Screen Assembly Replacement: adım 33, 3 resimden 3.
    • Use a pair of tweezers to pull the antenna cable out of its routing and remove it.
    FixBot'a Sor
    Yorum Ekle
  34. Moto C Screen Assembly Replacement: adım 34, 1 resimden 1.
    • Check your replacement part for any other components that need to be transferred before reassembly.
    • Maybe you also want to transfer the white label with the serial number and IMEI number on it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
261.738 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.535 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 42
Her zaman: 2,919
