Ana içeriğe geç
Motorola Droid RAZR Battery Replacement
Neye ihtiyacın var
  1. Motorola Droid RAZR Battery Replacement, Back Cover: adım 1, 2 resimden 1. Motorola Droid RAZR Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola Droid RAZR Battery Replacement: adım 2, 3 resimden 1. Motorola Droid RAZR Battery Replacement: adım 2, 3 resimden 2. Motorola Droid RAZR Battery Replacement: adım 2, 3 resimden 3.
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola Droid RAZR Battery Replacement: adım 3, 3 resimden 1. Motorola Droid RAZR Battery Replacement: adım 3, 3 resimden 2. Motorola Droid RAZR Battery Replacement: adım 3, 3 resimden 3.
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola Droid RAZR Battery Replacement, Battery: adım 4, 2 resimden 1. Motorola Droid RAZR Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola Droid RAZR Battery Replacement: adım 5, 3 resimden 1. Motorola Droid RAZR Battery Replacement: adım 5, 3 resimden 2. Motorola Droid RAZR Battery Replacement: adım 5, 3 resimden 3.
    • Remove the two 3.3 mm T5 Torx battery terminal screws.
    • Grab the blue battery removal tab and lift the battery out to remove it.
    • There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
    • Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
    FixBot'a Sor
    Yorum Ekle
Sonuç
46 farklı kişi bu kılavuzu tamamladı.
David Hodson
156.536 İtibar
127 adet Kılavuz yazıldı
8Kılavuz Yorumları
Where can i get a battery?
Jennifer Monticello - Yanıt Paylaş
You can find a replacement Droid Razr Battery at www.cellphone-repair-shop.com
H M - Yanıt Paylaş
Great guide. Honestly the spudger tool made it soooo easy.. I even used the spuder to remove the case from the phone. gently inserting the spudger while using slight pressure on removing the case. you could hear the small cracks as the adhesive gave way.. Take your time when doing this and it will come out just fine.... Also used the spudger on removing the battery from the case..... again carefully inserting the tool while pulling up slowly with the blue tab...
You guys rock.....Thanks again.
alphageek20 - Yanıt Paylaş
I bought a knock off brand battery off of amazon and used it. At first i thought it wouldn't work but after a little playing around with it i got it to fit. Big thing is be delicate, SLOWLY remove the back paneling and try not to bump the bottom thing where the screws go.
Thomas Butler - Yanıt Paylaş
Very helpful and informative article, it made it easy for me to fix my phone at home. Thank you a million!
Squedwart • - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 74
Her zaman: 212,366
