Ana içeriğe geç
Motorola Edge (2022) Camera Bezel Replacement
Neye ihtiyacın var
  1. Motorola Edge (2022) Camera Bezel Replacement, Heat the right edge: adım 1, 1 resimden 1.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge (2022) Camera Bezel Replacement, Insert an opening pick: adım 2, 2 resimden 1. Motorola Edge (2022) Camera Bezel Replacement, Insert an opening pick: adım 2, 2 resimden 2.
    • Insert an opening pick between the camera bezel and the back cover.
  3. Motorola Edge (2022) Camera Bezel Replacement, Slice the camera bezel adhesive: adım 3, 2 resimden 1. Motorola Edge (2022) Camera Bezel Replacement, Slice the camera bezel adhesive: adım 3, 2 resimden 2.
    • Slide the pick around the perimeter of the camera bezel to slice all the adhesive securing the bezel.
    • You may have to repeat this process multiple times to completely cut all of the adhesive.
  4. Motorola Edge (2022) Camera Bezel Replacement, Remove the camera bezel: adım 4, 2 resimden 1. Motorola Edge (2022) Camera Bezel Replacement, Remove the camera bezel: adım 4, 2 resimden 2.
    • Lift the camera bezel away from the phone and remove it.
Sonuç
To reassemble your device, follow the instructions in reverse order.
Spencer Day
61.610 İtibar
445 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.077 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 389
