Ana içeriğe geç
Motorola Moto E Battery Replacement
Neye ihtiyacın var
    1. Motorola Moto E  Battery Replacement, Battery: adım 1, 2 resimden 1. Motorola Moto E  Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Turn off the device before beginning the battery replacement.
      • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
      • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
      • You should hear a snapping sound at each corner.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Moto E  Battery Replacement: adım 2, 1 resimden 1.
      • Unscrew all 14- 4mm screws located on the back part of the phone using a T4 Torx bit.
      • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Moto E  Battery Replacement: adım 3, 1 resimden 1.
      • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
      • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Moto E  Battery Replacement: adım 4, 1 resimden 1.
      • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
      • Do not touch the connections to the battery in the red square on the picture.
      FixBot'a Sor
      Yorum Ekle
    5. Motorola Moto E  Battery Replacement: adım 5, 1 resimden 1.
      • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
      • Move the battery and cover away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Motorola Moto E  Battery Replacement: adım 6, 1 resimden 1.
      • Lift gently on the battery using the metal spudger tool.
      • The battery is stuck to the plastic case with double sided tape. You should hear the battery peeling away from the cover as you are pulling on it.
      • Obtain a new battery and place it into the plastic casing using double sided tape or whatever is provided with the new battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
36 farklı kişi bu kılavuzu tamamladı.
Alex Craig
2.611 İtibar
5 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 5-7, Panko Spring 2015 Colorado Springs, Team 5-7, Panko Spring 2015 üyesi
UCCS-PANKO-S15S5G7
2 Üyeler
35 adet Kılavuz yazıldı
7Kılavuz Yorumları
another quite superb guide from ifixit ....
I'm not surprised either as the guides on here are far and away the best available online.
keep up the good work contributors!
carol - Yanıt Paylaş
is it possible to fit Moto 2 gen battery into Moto 1 gen phone ?
Clement Santhosh - Yanıt Paylaş
This worked very well for me, many thanks!
Tony Franks - Yanıt Paylaş
which battery type or brand should we purchase????????
hridaya123.praja - Yanıt Paylaş
Excellent, clear instructions!
Gerald Griffin - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 27
Son 30 gün: 108
Her zaman: 79,452
