Ana içeriğe geç
Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement
Neye ihtiyacın var
  1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement, Remove the back cover: adım 1, 3 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement, Remove the back cover: adım 1, 3 resimden 2. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement, Remove the back cover: adım 1, 3 resimden 3.
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 2, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 2, 2 resimden 2.
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement, Midframe: adım 3, 1 resimden 1.
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 4, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 4, 2 resimden 2.
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 5, 3 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 5, 3 resimden 2. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 5, 3 resimden 3.
    • Remove the battery cover.
  6. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 6, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 6, 2 resimden 2.
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 7, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 7, 2 resimden 2.
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 8, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 8, 2 resimden 2.
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement, Battery Disconnect: adım 9, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement, Battery Disconnect: adım 9, 2 resimden 2.
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement, Motherboard Assembly: adım 10, 1 resimden 1.
    • Remove the two 2.9 mm Phillips screws.
  11. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 11, 3 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 11, 3 resimden 2. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 11, 3 resimden 3.
    • Use the edge of a spudger to pry up the flap of the ZIF connector located below the SIM slot on the left side of the motherboard.
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • To reattach ZIF connectors like this one, carefully insert the flex cable into the ZIF connector up to the marked line on the cable, and then close the locking flap.
  12. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 12, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 12, 2 resimden 2.
    • Use a pair of tweezers to pry up and disconnect the antenna cable.
  13. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 13, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 13, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the interconnect flex cable.
  14. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 14, 3 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 14, 3 resimden 2. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 14, 3 resimden 3.
    • Use the tip of a spudger or an opening pick to pry up the flap of the ZIF connector, located in the bottom right corner of the motherboard.
    • Use a pair of tweezers to pull the display flex cable out of the ZIF connector.
  15. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 15, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 15, 2 resimden 2.
    • Grasp the motherboard by the top corners and remove it by lifting up and pulling it carefully out of its recess.
  16. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement, Charging Board: adım 16, 1 resimden 1.
    • Remove the single 2.9 mm Phillips screw holding the charging board to the frame.
  17. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 17, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 17, 2 resimden 2.
  18. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 18, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 18, 2 resimden 2.
    • Use the edge of a spudger to pry up and disconnect the interconnect flex cable.
  19. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 19, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 19, 2 resimden 2.
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
  20. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 20, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 20, 2 resimden 2.
    • Insert the tip of a spudger underneath the bottom edge of the charging board and pry upwards.
    • Remove the charging board.
    • Before reassembly check your new part for any components that might need to be transferred from the old one (e.g. microphone rubber gasket).
  21. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement, Display: adım 21, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement, Display: adım 21, 2 resimden 2.
    • Use a pair of tweezers to peel the copper tape from the right edge until the display flex cable underneath is fully exposed.
  22. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 22, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 22, 2 resimden 2.
    • Use a pair of tweezers to carefully peel the display flex cable off of the midframe.
  23. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 23, 1 resimden 1.
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive underneath.
  24. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 24, 3 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 24, 3 resimden 2. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 24, 3 resimden 3.
    • Once the screen is warm to the touch, apply a suction cup near the top edge of the phone right under the earpiece speaker.
    • If the phone's screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Pull up the suction cup, and insert the tip of an opening pick under the display where the earpiece speaker is located.
    • Slide the opening pick to the top left corner of the phone to cut the adhesive.
  25. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 25, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 25, 2 resimden 2.
    • Insert a second opening pick and slide it to the top right corner of the phone.
  26. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 26, 3 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 26, 3 resimden 2. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 26, 3 resimden 3.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
    • Slide the opening pick from the top right corner down the right edge of the phone and cut the adhesive with it.
    • While cutting, make sure the pick slides under the display panel and not just between the display and the front glass.
    • Slide the opening pick around the bottom right corner.
  27. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 27, 3 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 27, 3 resimden 2. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 27, 3 resimden 3.
    • Slide the opening pick along the bottom edge of the phone and cut the adhesive.
    • Be careful around the home button, inserting only the tip of the opening pick to prevent damaging the button.
  28. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 28, 2 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 28, 2 resimden 2.
    • Repeat the previous heating and cutting procedure on the left edge of the phone to cut the remaining adhesive.
    • Try not to remove the display all the way yet. The fingerprint and display flex cables are still threaded through the midframe.
  29. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 29, 3 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 29, 3 resimden 2. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 29, 3 resimden 3.
    • Carefully thread the display cable at the top and the fingerprint sensor cable on the bottom through their gaps in the midframe.
    • Remove the LCD and digitizer.
    • Remove any remaining adhesive from the midframe, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • In case your new LCD and digitizer doesn't include the fingerprint sensor, you will need to continue with the fingerprint sensor guide to transfer it to the new LCD and digitizer.
  30. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement, Fingerprint Sensor: adım 30, 1 resimden 1.
    • Apply an iOpener to the bottom edge of the screen for about a minute to loosen the adhesive beneath the fingerprint sensor.
  31. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 31, 3 resimden 1. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 31, 3 resimden 2. Motorola Moto E4 Plus (XT1771) Fingerprint Sensor Replacement: adım 31, 3 resimden 3.
    • Carefully pry off the fingerprint sensor by lifting it with the edge of an opening pick.
    • Remove the fingerprint sensor with a pair of tweezers.
    • There's a small rubber gasket around the fingerprint sensor which you might need to transfer to your replacement sensor.
Sonuç
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
To reassemble your device, follow these instructions in reverse order and reapply adhesive where it’s necessary.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Bir başkası bu kılavuzu tamamladı.
Dominik Schnabelrauch
203.948 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
17.198 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 17
Her zaman: 2,061
