Ana içeriğe geç
Motorola Moto E4 Plus Motherboard Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Motorola Moto E4 Plus Motherboard Replacement, Back Plate and Battery: adım 1, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement, Back Plate and Battery: adım 1, 2 resimden 2.
    • Insert the spudger into the notch on the corner of the phone and lift up to remove the back case.
  2. Motorola Moto E4 Plus Motherboard Replacement: adım 2, 1 resimden 1.
    • Use the T4 Torx Screwdriver to remove the 17 3.2 mm screws in the back panel covering the battery.
  3. Motorola Moto E4 Plus Motherboard Replacement: adım 3, 3 resimden 1. Motorola Moto E4 Plus Motherboard Replacement: adım 3, 3 resimden 2. Motorola Moto E4 Plus Motherboard Replacement: adım 3, 3 resimden 3.
    • Lift up and remove the back panel.
  4. Motorola Moto E4 Plus Motherboard Replacement: adım 4, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement: adım 4, 2 resimden 2.
    • After removing the back panel, use the spudger to lift and detach the Battery Flux Cable from the Motherboard.
  5. Motorola Moto E4 Plus Motherboard Replacement: adım 5, 3 resimden 1. Motorola Moto E4 Plus Motherboard Replacement: adım 5, 3 resimden 2. Motorola Moto E4 Plus Motherboard Replacement: adım 5, 3 resimden 3.
    • Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape.
  6. Motorola Moto E4 Plus Motherboard Replacement, Rear Camera: adım 6, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement, Rear Camera: adım 6, 2 resimden 2.
    • Use a pair of tweezers to peel up the copper tape that covers the rear camera flex connector.
    • Fold the copper tape out of the way.
  7. Motorola Moto E4 Plus Motherboard Replacement: adım 7, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the rear camera flex cable.
  8. Motorola Moto E4 Plus Motherboard Replacement: adım 8, 1 resimden 1.
    • Carefully remove the rear camera with a pair of tweezers.
  9. Motorola Moto E4 Plus Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Use the T4 Torx Screwdriver to remove the 2 3.2 mm screws circled in the image.
  10. Motorola Moto E4 Plus Motherboard Replacement: adım 10, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement: adım 10, 2 resimden 2.
    • Use the Spudger to lift up and detach the Main Flex Cable from the Motherboard.
  11. Motorola Moto E4 Plus Motherboard Replacement: adım 11, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement: adım 11, 2 resimden 2.
    • Use the Spudger to lift up and detach the LCD Screen Flex Cable from the Motherboard.
  12. Motorola Moto E4 Plus Motherboard Replacement: adım 12, 1 resimden 1.
    • Use the Plastic Spudger to lift up and detach the Signal Flex Cable from the Motherboard. The Signal Flex Cable should still be attached to the body of the phone.
  13. Motorola Moto E4 Plus Motherboard Replacement: adım 13, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement: adım 13, 2 resimden 2.
    • Use the Spudger to lift up and remove the Motherboard from the phone.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Jack Haseman
1.396 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team S3-G2, Williams Spring 2018 Baylor, Team S3-G2, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S3G2
4 Üyeler
13 adet Kılavuz yazıldı
2 Yorum
guide states that there are 17 screws to remove (step 2) but there are 20 screws circled… Counting is hard I guess?
CPR South Portland - Yanıt
From step 9 it’s another phone. I’m guessing E4 (regular) but they are not the same. The vibration motor, second sim tray, and many other components disappear suddenly. Mixing different phones is very irresponsable and lazy.
Randy Sickmind - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 6,030
