Ana içeriğe geç
Motorola Moto E4 Plus Motherboard Replacement
Neye ihtiyacın var
  1. Motorola Moto E4 Plus Motherboard Replacement, Remove the back cover: adım 1, 3 resimden 1. Motorola Moto E4 Plus Motherboard Replacement, Remove the back cover: adım 1, 3 resimden 2. Motorola Moto E4 Plus Motherboard Replacement, Remove the back cover: adım 1, 3 resimden 3.
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Motherboard Replacement: adım 2, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement: adım 2, 2 resimden 2.
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Motherboard Replacement, Remove the midframe screws: adım 3, 1 resimden 1.
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Motherboard Replacement, Release the midframe clips: adım 4, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement, Release the midframe clips: adım 4, 2 resimden 2.
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Motherboard Replacement, Remove the midframe: adım 5, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement, Remove the midframe: adım 5, 2 resimden 2.
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the battery: adım 6, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the battery: adım 6, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the display cable: adım 7, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the display cable: adım 7, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the display cable from its motherboard socket, near the bottom left corner of the motherboard.
  8. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the antenna cable: adım 8, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the antenna cable: adım 8, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the antenna cable from its motherboard socket.
  9. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the interconnect cable: adım 9, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the interconnect cable: adım 9, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the interconnect cable from its motherboard socket.
  10. Motorola Moto E4 Plus Motherboard Replacement, Remove the motherboard screws: adım 10, 1 resimden 1.
    • Remove the two black 3.2 mm long T3 screws securing the motherboard.
  11. Motorola Moto E4 Plus Motherboard Replacement, Remove the motherboard: adım 11, 2 resimden 1. Motorola Moto E4 Plus Motherboard Replacement, Remove the motherboard: adım 11, 2 resimden 2.
    • Grasp the motherboard by the top corners and lift it out of the phone.
    • Remove the motherboard.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
3 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
258.916 İtibar
531 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.078 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 1,626
