Ana içeriğe geç
Motorola Moto E4 Plus Rear Camera Replacement
Neye ihtiyacın var
  1. Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: adım 1, 3 resimden 1. Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: adım 1, 3 resimden 2. Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: adım 1, 3 resimden 3.
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Rear Camera Replacement: adım 2, 2 resimden 1. Motorola Moto E4 Plus Rear Camera Replacement: adım 2, 2 resimden 2.
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Rear Camera Replacement, Midframe: adım 3, 1 resimden 1.
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus Rear Camera Replacement: adım 4, 2 resimden 1. Motorola Moto E4 Plus Rear Camera Replacement: adım 4, 2 resimden 2.
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus Rear Camera Replacement: adım 5, 3 resimden 1. Motorola Moto E4 Plus Rear Camera Replacement: adım 5, 3 resimden 2. Motorola Moto E4 Plus Rear Camera Replacement: adım 5, 3 resimden 3.
    • Remove the battery cover.
  6. Motorola Moto E4 Plus Rear Camera Replacement: adım 6, 2 resimden 1. Motorola Moto E4 Plus Rear Camera Replacement: adım 6, 2 resimden 2.
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus Rear Camera Replacement: adım 7, 2 resimden 1. Motorola Moto E4 Plus Rear Camera Replacement: adım 7, 2 resimden 2.
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus Rear Camera Replacement: adım 8, 2 resimden 1. Motorola Moto E4 Plus Rear Camera Replacement: adım 8, 2 resimden 2.
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus Rear Camera Replacement, Battery Disconnect: adım 9, 2 resimden 1. Motorola Moto E4 Plus Rear Camera Replacement, Battery Disconnect: adım 9, 2 resimden 2.
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus Rear Camera Replacement, Rear Camera: adım 10, 2 resimden 1. Motorola Moto E4 Plus Rear Camera Replacement, Rear Camera: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of tweezers to peel up the copper tape that covers the rear camera flex connector.
    • Fold the copper tape out of the way.
  11. Motorola Moto E4 Plus Rear Camera Replacement: adım 11, 2 resimden 1. Motorola Moto E4 Plus Rear Camera Replacement: adım 11, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the rear camera flex cable.
  12. Motorola Moto E4 Plus Rear Camera Replacement: adım 12, 1 resimden 1.
    • Carefully remove the rear camera with a pair of tweezers.
Sonuç
If possible, turn on your phone and test your repair before reassembly.
5 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
210.026 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
141 Üyeler
17.895 adet Kılavuz yazıldı
Bir Yorum
I want Moto e 4 + camera
Mubbu N - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 1,567
