Giriş
Use this guide to replace a broken or defective screen assembly of your Motorola Moto E4 (XT1762). This guide can also be used to replace the screen on a Moto E4 (XT1766) with a fingerprint sensor.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
This guide shows the procedure for the screen assembly including the frame. Make sure you have the correct part before starting this guide.
You may need replacement adhesive to reattach components during reassembly.
For replacing the LCD and digitizer only use this guide.
Neye ihtiyacın var
Insert a fingernail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
Move to the bottom left corner to pry the phone out of the back cover.
Use a fingernail or spudger to pry at the notch at the bottom end of the battery.
Lever the battery out of its recess and remove it.
Use a pair of tweezers to peel off the yellow tape of the ZIF connector located on the left of the motherboard.
Use a pair of tweezers to pry up and disconnect the antenna cable.
Apply a heated iOpener for about one minute to the upper part of the display to loosen the adhesive beneath the earpiece speaker.
Apply a heated iOpener to the left edge of the phone for about 30 seconds to loosen the adhesive beneath power and volume button unit.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
3 farklı kişi bu kılavuzu tamamladı.
