Ana içeriğe geç
Motorola Moto E6 Play Back Facing Camera Replacement
Neye ihtiyacın var
  1. Motorola Moto E6 Play Back Facing Camera Replacement, Back Cover: adım 1, 2 resimden 1. Motorola Moto E6 Play Back Facing Camera Replacement, Back Cover: adım 1, 2 resimden 2.
    • Run the halberd spudger along the edges of the device. The back cover should easily pop off.
    • Gently remove the back cover. Do not pull hard, as it is still connected to the fingerprint scanner inside the phone.
  2. Motorola Moto E6 Play Back Facing Camera Replacement, Circuit Board Covers: adım 2, 2 resimden 1. Motorola Moto E6 Play Back Facing Camera Replacement, Circuit Board Covers: adım 2, 2 resimden 2.
    • To remove the cover on the motherboard, remove the 10 silver 3.90 mm Phillips screws attaching the cover to the board using the Phillips #0 screwdriver.
    • One of these ten screws is covered by black tape located at the bottom left corner of the black cover. Peel back the black tape to access this screw.
  3. Motorola Moto E6 Play Back Facing Camera Replacement: adım 3, 2 resimden 1. Motorola Moto E6 Play Back Facing Camera Replacement: adım 3, 2 resimden 2.
    • With the angled tweezers, remove the black cover to reveal the motherboard underneath.
    • Remove the black piece cover with caution to avoid puncturing the motherboard with the tweezers.
  4. Motorola Moto E6 Play Back Facing Camera Replacement: adım 4, 3 resimden 1. Motorola Moto E6 Play Back Facing Camera Replacement: adım 4, 3 resimden 2. Motorola Moto E6 Play Back Facing Camera Replacement: adım 4, 3 resimden 3.
    • The bottom plastic piece covering the daughterboard can be seen by peeling back the tape covering the bottom section of the phone below the battery.
    • To remove the cover, unscrew the six black 3.45 mm Phillips screws holding the cover in place using the Phillips #0 screwdriver.
  5. Motorola Moto E6 Play Back Facing Camera Replacement: adım 5, 2 resimden 1. Motorola Moto E6 Play Back Facing Camera Replacement: adım 5, 2 resimden 2.
    • Remove the black cover piece using the angled tweezers.
  6. Motorola Moto E6 Play Back Facing Camera Replacement, Back Facing Camera: adım 6, 2 resimden 1. Motorola Moto E6 Play Back Facing Camera Replacement, Back Facing Camera: adım 6, 2 resimden 2.
    • Use the angled tweezers to pry off the metal head of the connecting piece from the main motherboard assembly.
  7. Motorola Moto E6 Play Back Facing Camera Replacement: adım 7, 2 resimden 1. Motorola Moto E6 Play Back Facing Camera Replacement: adım 7, 2 resimden 2.
    • Using the angled tweezers, detach the two connectors from the motherboard by pulling the metallic head up and away from the phone.
  8. Motorola Moto E6 Play Back Facing Camera Replacement: adım 8, 2 resimden 1. Motorola Moto E6 Play Back Facing Camera Replacement: adım 8, 2 resimden 2.
    • Use the angled tweezers to flip the black plastic piece from flat to upright.
    • This will allow you to separate the mini connector from the motherboard later.
  9. Motorola Moto E6 Play Back Facing Camera Replacement: adım 9, 2 resimden 1. Motorola Moto E6 Play Back Facing Camera Replacement: adım 9, 2 resimden 2.
    • Disconnect the rod connected to the motherboard using the angled tweezers.
    • Gently pull the small metal head of the vertically perpendicular from the motherboard with caution to avoid puncturing the board with the tweezers.
  10. Motorola Moto E6 Play Back Facing Camera Replacement: adım 10, 2 resimden 1. Motorola Moto E6 Play Back Facing Camera Replacement: adım 10, 2 resimden 2.
    • Using the angled tweezers, gently lift and pull the tab at the bottom of the camera to remove the back facing camera from the circuit board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Charlie Priebe
824 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G4, Regan Winter 2020 Cal Poly, Team S22-G4, Regan Winter 2020 üyesi
CPSU-REGAN-W20S22G4
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 301
