Giriş
This guide shows you how to replace the speaker on a Motorola Moto G 1st Generation smartphone.
Neye ihtiyacın var
Adım 1 Rear Panel
Dikkatli ol: adımlar 1-3 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
Use a plastic opening tool to remove the protective cover.
Use the plastic opening tool to remove the Speaker from the protective cover.
2 farklı kişi bu kılavuzu tamamladı.
