Ana içeriğe geç
Motorola Moto G 5G (2022) Earpiece Speaker Replacement
Neye ihtiyacın var
  1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Eject the SIM card tray: adım 1, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Eject the SIM card tray: adım 1, 2 resimden 2.
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
  2. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the SIM card tray: adım 2, 1 resimden 1.
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
  3. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Back cover removal information: adım 3, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Back cover removal information: adım 3, 2 resimden 2.
    • Discharge your battery to 25% or less and completely power off your phone before you begin.
    • Take note of the following seams along the edge of the phone:
    • Screen seam: This seam separates the display panel from the frame. Don't pry at this seam.
    • Bezel seam: This is where the plastic back cover meets the rest of the phone. It's held in place by plastic clips. This is where you should pry.
  4. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Insert an opening pick: adım 4, 3 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Insert an opening pick: adım 4, 3 resimden 2. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • Insert an opening tool in the bezel seam halfway between the bottom-right corner of the phone and the power button.
    • Insert an opening pick in the gap you just created.
  5. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Release the right clips: adım 5, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Release the right clips: adım 5, 2 resimden 2.
    • Slide your opening pick toward the bottom-right corner of the back cover and release the clips.
    • As each clip releases, you will hear and feel a pop.
    • Don't slide the opening pick near the power or volume buttons.
  6. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Release the bottom clips: adım 6, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Release the bottom clips: adım 6, 2 resimden 2.
    • Continue sliding your opening pick towards the bottom left corner to unclip the bottom edge of the back cover.
  7. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Release the left clips: adım 7, 3 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Release the left clips: adım 7, 3 resimden 2. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Release the left clips: adım 7, 3 resimden 3.
    • Slide your opening pick toward the top left corner to unclip the left side of the back cover.
  8. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Release the top clips: adım 8, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Release the top clips: adım 8, 2 resimden 2.
    • Slide your pick around the top left corner and along the top edge to release the clips.
  9. Motorola Moto G 5G (2022) Earpiece Speaker Replacement: adım 9, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement: adım 9, 2 resimden 2.
    • Slide your pick around the top right corner to release the last clips securing the back cover.
    • Stop before reaching the volume buttons. Your pick may damage their cables.
  10. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the back cover: adım 10, 3 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the back cover: adım 10, 3 resimden 2. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the back cover: adım 10, 3 resimden 3.
    • Don't try to remove the back cover all the way yet, as it's still connected to the frame by the power button cable.
    • With SIM card slot facing you, swing the back cover open and away from you like you're opening a book.
    • Rest the cover parallel to the frame.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the power button cable.
  11. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the power button: adım 11, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the power button: adım 11, 2 resimden 2.
    Bu adımda kullanılan alet:
    • A small rubber arm connects the power button to its recess. Use caution to avoid tearing this piece.
    • Use tweezers or your fingers to unhook the power button's rubber arm from its recess and remove it.
  12. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Only the back cover remains: adım 12, 1 resimden 1.
    • You're now left with the back cover.
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
  13. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Unfasten the power button cable bracket: adım 13, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Unfasten the power button cable bracket: adım 13, 2 resimden 2.
    • Use a PH00 screwdriver to remove the two 3.9 mm-long screws securing the power button cable bracket.
  14. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the power button cable bracket: adım 14, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the power button cable bracket: adım 14, 2 resimden 2.
    • Use your fingers or a pair of blunt nose tweezers to grab and remove the bracket from the power button cable.
  15. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Disconnect the power button: adım 15, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Disconnect the power button: adım 15, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the power button's press connector.
  16. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the power button: adım 16, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the power button: adım 16, 2 resimden 2.
    • Grab and remove the power button.
    • If you're using tweezers, take care not to puncture the battery—a punctured battery may leak dangerous chemicals or cause a fire.
  17. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Unfasten the motherboard cover: adım 17, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Unfasten the motherboard cover: adım 17, 2 resimden 2.
    • Use your Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
  18. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Pry the motherboard cover: adım 18, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Pry the motherboard cover: adım 18, 2 resimden 2.
    • Insert an opening pick between the bottom-left corner of the cover and the motherboard.
    • Pry up to release the cover's small clips securing it to the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • Work your way around the perimeter to free the cover if it feels stuck.
  19. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the motherboard cover: adım 19, 3 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the motherboard cover: adım 19, 3 resimden 2. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the motherboard cover: adım 19, 3 resimden 3.
    • Grab and remove the motherboard cover from the phone.
  20. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Disconnect the battery: adım 20, 2 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Disconnect the battery: adım 20, 2 resimden 2.
    • Use the pointed end of a spudger to pry and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the earpiece speaker: adım 21, 3 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the earpiece speaker: adım 21, 3 resimden 2. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Remove the earpiece speaker: adım 21, 3 resimden 3.
    • Insert the point of a spudger into the small gap on the lower right side of the earpiece speaker's recess.
    • Pry up on the speaker and remove it.
  22. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Reassembly information: adım 22, 3 resimden 1. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Reassembly information: adım 22, 3 resimden 2. Motorola Moto G 5G (2022) Earpiece Speaker Replacement, Reassembly information: adım 22, 3 resimden 3.
    • Note the orientation of the earpiece speaker. Ensure that the raised side of the connectors are toward the bottom of the device.
    • Don't install the earpiece speaker without its mesh in the frame. Transfer the mesh from your old part, if needed.
Sonuç
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Clay Eickemeyer
82.297 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.499 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 774
