Ana içeriğe geç
Motorola Moto G 5G (2022) Motherboard Replacement
Neye ihtiyacın var
  1. Motorola Moto G 5G (2022) Motherboard Replacement, Eject the SIM card tray: adım 1, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Eject the SIM card tray: adım 1, 2 resimden 2.
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
  2. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the SIM card tray: adım 2, 1 resimden 1.
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
  3. Motorola Moto G 5G (2022) Motherboard Replacement, Back cover removal information: adım 3, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Back cover removal information: adım 3, 2 resimden 2.
    • Discharge your battery to 25% or less and completely power off your phone before you begin.
    • Take note of the following seams along the edge of the phone:
    • Screen seam: This seam separates the display panel from the frame. Don't pry at this seam.
    • Bezel seam: This is where the plastic back cover meets the rest of the phone. It's held in place by plastic clips. This is where you should pry.
  4. Motorola Moto G 5G (2022) Motherboard Replacement, Insert an opening pick: adım 4, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Insert an opening pick: adım 4, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • Insert an opening tool in the bezel seam halfway between the bottom-right corner of the phone and the power button.
    • Insert an opening pick in the gap you just created.
  5. Motorola Moto G 5G (2022) Motherboard Replacement, Release the right clips: adım 5, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Release the right clips: adım 5, 2 resimden 2.
    • Slide your opening pick toward the bottom-right corner of the back cover and release the clips.
    • As each clip releases, you will hear and feel a pop.
    • Don't slide the opening pick near the power or volume buttons.
  6. Motorola Moto G 5G (2022) Motherboard Replacement, Release the bottom clips: adım 6, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Release the bottom clips: adım 6, 2 resimden 2.
    • Continue sliding your opening pick towards the bottom left corner to unclip the bottom edge of the back cover.
  7. Motorola Moto G 5G (2022) Motherboard Replacement, Release the left clips: adım 7, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Release the left clips: adım 7, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Release the left clips: adım 7, 3 resimden 3.
    • Slide your opening pick toward the top left corner to unclip the left side of the back cover.
  8. Motorola Moto G 5G (2022) Motherboard Replacement, Release the top clips: adım 8, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Release the top clips: adım 8, 2 resimden 2.
    • Slide your pick around the top left corner and along the top edge to release the clips.
  9. Motorola Moto G 5G (2022) Motherboard Replacement: adım 9, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement: adım 9, 2 resimden 2.
    • Slide your pick around the top right corner to release the last clips securing the back cover.
    • Stop before reaching the volume buttons. Your pick may damage their cables.
  10. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the back cover: adım 10, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the back cover: adım 10, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the back cover: adım 10, 3 resimden 3.
    • Don't try to remove the back cover all the way yet, as it's still connected to the frame by the power button cable.
    • With SIM card slot facing you, swing the back cover open and away from you like you're opening a book.
    • Rest the cover parallel to the frame.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the power button cable.
  11. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the power button: adım 11, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the power button: adım 11, 2 resimden 2.
    Bu adımda kullanılan alet:
    • A small rubber arm connects the power button to its recess. Use caution to avoid tearing this piece.
    • Use tweezers or your fingers to unhook the power button's rubber arm from its recess and remove it.
  12. Motorola Moto G 5G (2022) Motherboard Replacement, Only the back cover remains: adım 12, 1 resimden 1.
    • You're now left with the back cover.
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
  13. Motorola Moto G 5G (2022) Motherboard Replacement, Unfasten the power button cable bracket: adım 13, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Unfasten the power button cable bracket: adım 13, 2 resimden 2.
    • Use a PH00 screwdriver to remove the two 3.9 mm-long screws securing the power button cable bracket.
  14. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the power button cable bracket: adım 14, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the power button cable bracket: adım 14, 2 resimden 2.
    • Use your fingers or a pair of blunt nose tweezers to grab and remove the bracket from the power button cable.
  15. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the power button: adım 15, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the power button: adım 15, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the power button's press connector.
  16. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the power button: adım 16, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the power button: adım 16, 2 resimden 2.
    • Grab and remove the power button.
    • If you're using tweezers, take care not to puncture the battery—a punctured battery may leak dangerous chemicals or cause a fire.
  17. Motorola Moto G 5G (2022) Motherboard Replacement, Unfasten the motherboard cover: adım 17, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Unfasten the motherboard cover: adım 17, 2 resimden 2.
    • Use your Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
  18. Motorola Moto G 5G (2022) Motherboard Replacement, Pry the motherboard cover: adım 18, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Pry the motherboard cover: adım 18, 2 resimden 2.
    • Insert an opening pick between the bottom-left corner of the cover and the motherboard.
    • Pry up to release the cover's small clips securing it to the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • Work your way around the perimeter to free the cover if it feels stuck.
  19. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the motherboard cover: adım 19, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the motherboard cover: adım 19, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the motherboard cover: adım 19, 3 resimden 3.
    • Grab and remove the motherboard cover from the phone.
  20. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the battery: adım 20, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the battery: adım 20, 2 resimden 2.
    • Use the pointed end of a spudger to pry and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Motorola Moto G 5G (2022) Motherboard Replacement, Peel away the tape: adım 21, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Peel away the tape: adım 21, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Peel away the tape: adım 21, 3 resimden 3.
    • Peel the tape from the display connector.
    • If you are using a pair of tweezers, use caution to avoid the battery.
    • If you're having trouble peeling the tape, heat an iOpener and apply it to the tape for 60 seconds.
  22. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the display: adım 22, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the display: adım 22, 2 resimden 2.
    • Use the pointed end of a spudger to pry and disconnect the screen's press connector.
  23. Motorola Moto G 5G (2022) Motherboard Replacement, Lift the graphite film: adım 23, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Lift the graphite film: adım 23, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Lift the graphite film: adım 23, 3 resimden 3.
    • Fold the graphite heat film away from the battery to expose the lower section of the motherboard.
  24. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the board connector: adım 24, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the board connector: adım 24, 2 resimden 2.
    • Use the pointed end of a spudger to pry and disconnect the board cable's press connector.
  25. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the black antenna cable: adım 25, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the black antenna cable: adım 25, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the black antenna cable: adım 25, 3 resimden 3.
    • Use the pointed end of your spudger to pry and disconnect the head of the black antenna cable.
    • Pry on only the metal head of the connector. Avoid lifting the cable itself as much as possible.
    • Free the cable from the clip below the head of the connector.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
    • During reassembly, make sure to secure the cable to the clip below the head of the connector.
  26. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the white antenna cable: adım 26, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the white antenna cable: adım 26, 2 resimden 2.
    • Repeat the previous step for the white antenna cable.
  27. Motorola Moto G 5G (2022) Motherboard Replacement, Unfasten the motherboard: adım 27, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Unfasten the motherboard: adım 27, 2 resimden 2.
    • Use your Phillips screwdriver to remove the 2.9 mm-long screw from the bottom-right corner of the motherboard.
  28. Motorola Moto G 5G (2022) Motherboard Replacement, Lift the motherboard: adım 28, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Lift the motherboard: adım 28, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Lift the motherboard: adım 28, 3 resimden 3.
    • Insert the pointed end of a spudger between the lower left of the motherboard and the frame.
    • Lift upward on this bottom edge to free the motherboard from the frame.
  29. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the motherboard: adım 29, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the motherboard: adım 29, 2 resimden 2.
    • Grab the motherboard from the bottom edge and lift it from its recess.
    • Be sure the loose cables don't catch on the motherboard as its removed.
  30. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the main camera: adım 30, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the main camera: adım 30, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the main camera: adım 30, 3 resimden 3.
    • Flip the motherboard over so that the lens of the main camera is facing down.
    • Use the pointed end of your spudger to pry and disconnect the main camera's press connector.
    • Remove the main camera from the motherboard.
  31. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the macro camera: adım 31, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the macro camera: adım 31, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the macro camera: adım 31, 3 resimden 3.
    • Use the pointed end of a spudger to pry and disconnect the macro camera's press connector.
    • The camera may eject from the motherboard. Be careful to not lose it.
    • Grab and remove the macro camera.
  32. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the depth camera: adım 32, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the depth camera: adım 32, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the depth camera: adım 32, 3 resimden 3.
    • Use the pointed end of a spudger to pry and disconnect the depth camera's press connector.
    • Grab and remove the depth camera.
  33. Motorola Moto G 5G (2022) Motherboard Replacement, Peel away the tape: adım 33, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Peel away the tape: adım 33, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Peel away the tape: adım 33, 3 resimden 3.
    • Use a pair of tweezers to peel the tape connecting the front-facing camera to the motherboard.
  34. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the front-facing camera: adım 34, 3 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the front-facing camera: adım 34, 3 resimden 2. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the front-facing camera: adım 34, 3 resimden 3.
    • Use the pointed end of a spudger to pry and disconnect the camera's press connector.
    • Grab and remove the camera.
  35. Motorola Moto G 5G (2022) Motherboard Replacement: adım 35, 2 resimden 1. Motorola Moto G 5G (2022) Motherboard Replacement: adım 35, 2 resimden 2.
    • All that remains is the motherboard.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Bir başkası bu kılavuzu tamamladı.
Clay Eickemeyer
82.327 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.502 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 41
Her zaman: 1,196
