Ana içeriğe geç
Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement
Neye ihtiyacın var
  1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement, Back Cover: adım 1, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement, Back Cover: adım 1, 2 resimden 2.
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 2, 3 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 2, 3 resimden 2. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 2, 3 resimden 3.
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 3, 3 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 3, 3 resimden 2. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 3, 3 resimden 3.
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 4, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 4, 2 resimden 2.
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement, Battery: adım 5, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement, Battery: adım 5, 2 resimden 2.
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement, LCD Screen and Digitizer Assembly: adım 7, 1 resimden 1.
    • Remove the sixteen 3 mm Phillips screws securing the motherboard and daughterboard covers.
  8. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 8, 3 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 8, 3 resimden 2. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 8, 3 resimden 3.
    • Insert the flat end of a spudger into the seam below the daughterboard cover.
    • Twist the spudger slightly to free the daughterboard cover.
    • Remove the daughterboard cover.
  9. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 9, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 9, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the antenna cable from the daughterboard.
  10. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 10, 3 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 10, 3 resimden 2. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 10, 3 resimden 3.
    • Use the point of a spudger to pry up and disconnect the two flex cable connectors from the daughterboard.
  11. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 11, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 11, 2 resimden 2.
    • Use the point of a spudger to pry up and loosen the vibration motor from its recess.
    • The vibration motor can remain attached to the daughterboard.
  12. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 12, 1 resimden 1.
    • Remove the 3.4 mm Phillips screw securing the daughterboard to the frame.
  13. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 13, 3 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 13, 3 resimden 2. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 13, 3 resimden 3.
    • Insert the flat end of a spudger below the daughterboard, near the charging port.
    • Pry the daughterboard up slightly with the spudger to loosen it from its recess.
    • Lift and remove the daughterboard, taking care not to snare any cables.
  14. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 14, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 14, 2 resimden 2.
    • Insert an opening tool into the seam on the right side of the phone near the top.
    • Gently pry upwards until the hidden clip on the motherboard cover releases.
  15. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 15, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 15, 2 resimden 2.
    • Insert an opening tool into the seam on the top of the phone, to the right of the indent.
  16. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 16, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 16, 2 resimden 2.
    • Insert an opening tool in the seam on the left edge of the phone, near the top.
  17. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 17, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 17, 2 resimden 2.
    • Make sure the three clips on the motherboard cover have not re-engaged.
    • Lift up and remove the motherboard cover.
  18. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 18, 1 resimden 1.
    • Remove the two 4 mm Phillips screws securing the motherboard.
  19. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 19, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 19, 2 resimden 2.
    • Use the point of a spudger to pry up and loosen the front facing camera module from its recess.
    • The camera module can remain connected to the motherboard.
  20. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 20, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 20, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the display connector from the motherboard.
  21. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 21, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 21, 2 resimden 2.
    • Take note of which motherboard socket the antenna cable is attached to. The triangle cutout on the motherboard shield points to the correct socket.
    • Use the point of a spudger to pry up and disconnect the antenna cable from the motherboard.
    • Be sure to attach the antenna cable to the same socket during reinstallation.
  22. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 22, 3 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 22, 3 resimden 2. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 22, 3 resimden 3.
    • Insert the flat end of a spudger underneath the motherboard, near the top edge of the phone.
    • Twist the spudger slightly to loosen the motherboard from the frame.
    • Swing the top edge of the motherboard upwards, making sure it does not snag any cables.
    • Do not remove the motherboard yet. It is still connected by a flex cable.
  23. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 23, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 23, 2 resimden 2.
    • While supporting the motherboard at an angle, use the point of a spudger to pry out and disconnect the flex cable connector underneath the motherboard.
    • To reattach the connector, support the motherboard at a slight angle and line up the connector. Press the connector against the socket gently with your finger until it seats fully.
  24. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 24, 1 resimden 1.
    • Lift up and remove the motherboard.
  25. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 25, 3 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 25, 3 resimden 2. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 25, 3 resimden 3.
    • Use the point of a spudger to pry up a corner of the black battery mat.
    • Use your fingers to peel the battery mat from the frame.
  26. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 26, 2 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 26, 2 resimden 2.
    • Use your fingers to lift and de-route the antenna cable from the right edge of the phone.
    • Be sure to re-route the antenna cable back onto the right edge of the phone before you replace the battery mat. The mat has a lip which holds the antenna cable in.
  27. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 27, 3 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 27, 3 resimden 2. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 27, 3 resimden 3.
    • Insert an opening pick under the daughterboard flex cable.
    • Slide the pick along the underside of the cable, releasing it from the frame.
    • Remove the daughterboard flex cable.
  28. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 28, 3 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 28, 3 resimden 2. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 28, 3 resimden 3.
    • Use the flat end of a spudger to pry up and loosen the earpiece module from its recess.
    • Remove the earpiece module.
    • During re-installation, be sure to check the orientation of the earpiece module and reinstall it the same way.
  29. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 29, 3 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 29, 3 resimden 2. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 29, 3 resimden 3.
    • Insert an opening pick underneath the button contact flex cable.
    • Slide the opening pick to loosen the button contact flex cable from the frame.
  30. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 30, 3 resimden 1. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 30, 3 resimden 2. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 30, 3 resimden 3.
    • Insert an opening pick between the button assembly and the frame.
    • Gently slide the pick to release the button assembly from the frame.
    • Remove the button assembly.
  31. Motorola Moto G5 LCD Screen and Digitizer Assembly Replacement: adım 31, 1 resimden 1.
    • Only the LCD screen and digitizer assembly (with frame) remains.
    • Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Sonuç
Repair didn’t go as planned? Check out our Motorola Moto G5 Answers community for troubleshooting help.
18 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
313.791 İtibar
729 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.779 adet Kılavuz yazıldı
11Kılavuz Yorumları
Thanks. These tips, plus the Moto G5 Plus guide solved my problem. The replacement I purchased was only for the LCD (needed to heat and remove the glass after disassembling the whole phone). Again, thanks.
Jeffo Moreira - Yanıt
Thanks a lot for this guide! A few things I noticed while I was doing it:
-There’s no screws to remove on one of the red circles on the bottom right (it’s not a hole for a screw!)
-The front speakers are not in the right position in the picture. I followed that, and I didn’t had any sound anymore. Flipping it fixed the problem.
Otherwise I’m really glad you made that tutorial, thank you very much !!!
Quentin Igier - Yanıt
Hi Quentin,
Thank you for the notes! I have updated the guide to reflect the changes!
Arthur Shi -
There are seams between housing and display assembly, as well as between various other parts of the phone. These become overstretched and unusable during disassembly. Buy a set of seams and double-sided tape specifically made for the G5, or it will become even less waterproof than before. Unfortunately, I have only found sources for those parts in the US.
Christoph Sold - Yanıt
This guide was great, made the job very easy. I was even able to reuse some of the rubber seams.
I had a few small issues when reassembling the device. I failed twice to adjust the antenna to the correct position (always to much on one side) and the big ribbon cable wouldn’t stay in place anymore. To work around this I connected the big ribon cable and the antenna to both boards before placing them inside the phone case, that way everything was already in the right place and I then used the battery mat to hold the big ribon cable in place. After that I only needed to install the speaker back and add the screws.
Jean P - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 33
Son 30 gün: 150
Her zaman: 27,182
