Giriş
The Motorola Moto G6 contains a speaker that can be replaced without taking off the motherboard. To access the speaker, the interior plate must be removed. If the speaker is too quiet or broken, a speaker replacement will most likely be the solution.
This guide teaches how to perform a speaker replacement. No repair experience is required this is a simple process with no hard to find tools that can be purchased on iFixit. The specific device model in this guide is XT1925-12. Other model numbers include: XT1925-4, XT1925-5, XT1925-6, and XT1925DL.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Before beginning the repair, make sure the device is turned off and disconnected from an external power source. Gather the suggested tools listed below and begin the replacement.
Neye ihtiyacın var
If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
Use a pair of tweezers to carefully peel up the black tape covering the battery.
Remove the tape.
Use a Phillips driver to remove seventeen screws securing the plastic cover:
Eleven grey 3 mm-long screws
Five black 2.5 mm-long screws
One silver 3.5 mm-long screw
Use the pointed end of a spudger to pry up the battery connector and disconnect it.
11 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Excellent guide Bradley - distinguishing all the screw sizes and positions really made me sure of the correct reassembly. Thank you for contributing.
