Giriş
Use this guide to replace your volume buttons.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Neye ihtiyacın var
Apply a heated iOpener to the lower glass panel on the back of the phone for five minutes.
Slide the spudger along the side of the phone until you get to the clip securing the display to the rear case.
With the spudger right next to the clip, carefully twist the spudger to pry the display away from the rear case and release the clip.
Tilt the top right corner of the display down to disengage one of the tabs that secure the top of the display.
Tilt the other corner down next, to disengage the other tab.
Lift the right edge of the display to hinge the phone open like a book, no more than 45°.
Gently lift the display enough to clear the clip from the edge of the rear case, maintaining the 45º angle.
Rest the display on the table behind the phone and open to 90º to allow access to the display cable.
Bu adımda kullanılan alet:Tweezers$4.99
Use tweezers to peel the black tape on the top of the battery up from the motherboard EMI shielding.
Use tweezers to gently peel the battery pull tab up enough to grab.
Use your fingers to grip the battery pull tab and lift the battery up from the phone.
If the pull tab breaks, use the flat end of a spudger or an old credit card to pry up carefully on the edges of the battery until it comes loose.
Use tweezers to flip open the ZIF connector and remove the vibrator ribbon cable.
Bir başkası bu kılavuzu tamamladı.
