Giriş
If your Moto Z2 Force camera is damaged or broken, this guide will show you how to replace it.
Parçalar
Hiçbir parça belirtilmedi.
Place the phone on a flat surface with the screen facing up.
Insert the flat end of a nylon spudger into the crease separating the screen and the body in the lower right corner of the phone.
Pry open part of the screen by pulling the tool and the screen toward you.
Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open.
Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you.
Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
Insert the flat end of the nylon spudger on the side of the rear facing camera closest to the battery.
Pry up the camera by pushing down on the spudger until the camera pops up.
