Ana içeriğe geç
Motorola RAZR V3i Battery Replacement
Neye ihtiyacın var
  1. Motorola RAZR V3i Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
    • If you have a phone case, it has to be removed.
  2. Motorola RAZR V3i Battery Replacement: adım 2, 3 resimden 1. Motorola RAZR V3i Battery Replacement: adım 2, 3 resimden 2. Motorola RAZR V3i Battery Replacement: adım 2, 3 resimden 3.
    • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
    • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
    • The flat edge of a credit card or other flat object will also work.
  3. Motorola RAZR V3i Battery Replacement: adım 3, 3 resimden 1. Motorola RAZR V3i Battery Replacement: adım 3, 3 resimden 2. Motorola RAZR V3i Battery Replacement: adım 3, 3 resimden 3.
    • Remove the battery by pushing down on it from the top while gently pulling it outwards.
    • Be careful not to use too much force as the battery retaining tab could be damaged.
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
Nigel
133 İtibar
2 adet Kılavuz yazıldı
Ekip
Cuesta, Team 1-5, Zipperian Fall 2011 Cuesta, Team 1-5, Zipperian Fall 2011 üyesi
CUESTA-ZIPPERIAN-F11S1G5
1 Üye
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 7,667
